Date/Time: Tue, 14 May 2024 02:42:43 +0000
Changed to Denali/TT and Sierra Chart showing incorrect values, open positions, etc.
View Count: 757
[2020-04-03 15:37:38] |
User240655 - Posts: 26 |
Hello, I changed to Denali/TT combo yesterday and I have been having problems since than. The platform is showing open positions in the Chart Stats tab although I have confirmed flat with AMP. Also the Account Balances tab shows that over 100 USD was taken from my account today despite the fact that I am up about 30 USD today. And I cannot see the trades that I made today in the Trade tab. So it appears that Sierra Chart is showing incorrect values and is acting strange when I want to close positions. When I entered the trades it gave me an error message in the log. Could you please help me with this? Thank you very much. Tomas Date Time Of Last Edit: 2020-04-03 18:19:50
[2020-04-03 18:49:57] |
The platform is showing open positions in the Chart Stats tab although I have confirmed flat with AMP. Update Sierra Chart to the current version:Software Download: Fast Update For the charts that you see on the Trade Stats for Charts tab, make sure this option is enabled for each one: Chart Settings: Filter Initial Fills Which Are Part of Existing Position (Chart >> Chart Settings >> Trading menu) And set the Order Fills Start Date-Time to 0: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) If you still have a problem, then refer to: Trade Activity Log: Solving Inaccurate Trade Statistics for Charts Field Values Also the Account Balances tab shows that over 100 USD was taken from my account today despite the fact that I am up about 30 USD today.
Regarding these fields of data, refer to:https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#UnsupportedPositionAndAccountBalanceFields They can be slow to update. And if there any inaccuracies this is not within our control. And I cannot see the trades that I made today in the Trade tab.
This step should not be relevant to the issue but we want you to convert the trade activity format as explained here:Select File >> Disconnect. Select Global Settings >> Convert Trade Activity Format. Select File >> Connect to Data Feed. This procedure only needs to be done once. After that, follow the instructions here: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-03 18:52:01
[2020-04-06 09:51:27] |
Thank you for the instructions, but unfortunately, I was not able to correct the problems. 1) Sierra Chart updated to the current version. 2) In my charts, there is no RefBy: #, so I could not complete this step. 3) The Order Fills Start Date-Time collums are blank, so I do not know if I need to do something with it. I can see the correct sum in my Account Balances tab now. It corrected by itself after some time. But I still cannot see any trades in the Trade tab (I converted trade activity format, etc. but no good). And in the Chart Stats tab, it is still showing an open position. Thank you. |
[2020-04-07 19:02:53] |
2. You must be looking at the wrong documentation. You are talking about chart references by studies and this is wholly unrelated. Not sure how you got to that documentation. We did not link to it. But I still cannot see any trades in the Trade tab (I converted trade activity format, etc. but no good). Select the Trade >> Trade Activity Log >> Trade Activity menu item and then provide a screenshot of the top of the Trade Activity Log:https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile And in the Chart Stats tab, it is still showing an open position. In regards to this, follow the steps here:Trade Activity Log: Setting Chart Order Fills Start Date-Time (Setting Chart Order Fills Start Date-Time ) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-07 19:03:30
