Date/Time: Wed, 30 Sep 2026 10:14:50 +0000
a quote
View Count: 871
| [2020-04-02 16:47:30] |
| User981697 - Posts: 32 |
i want to conect the cl contract quote who do i do it ?
| [2020-04-02 18:01:36] |
The easiest thing to do is to use the Delayed Exchange Data Feed: Delayed Exchange Data Feed The current crude oil symbol is CLK20. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-04-03 10:07:52] |
i want to pay for real time data were do i do it?
| [2020-04-03 10:41:37] |
i paid 56$ ulredy for real time data but its not working. who do i do it?
| [2020-04-03 10:56:27] |
The reason you are not getting real-time data from the CME group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-04-03 11:11:17] |
i have account whit interactive brokers but i am not trading now i want to get from you only the data |
| [2020-04-03 11:15:53] |
i want the data for only nymex..
| [2020-04-03 11:20:27] |
Then you need to pay the professional NYMEX fee which is about 110 USD a-month.
| [2020-04-03 11:24:38] |
can you send me link to this payment? i alredy paid 56 $
| [2020-04-03 11:24:39] |
| [2020-04-03 14:40:05] |
ok i paid another 45 $ so whit the 56$ its 101$ who do i reconect to the crude oil data |
| [2020-04-03 14:42:45] |
soory 110$
| [2020-04-03 18:50:19] |
| John - SC Support - Posts: 48062 |
The first thing we need for you to do is to complete the User Agreements for the Denali Exchange Data Feed. We have sent you an email as well that gives you the links to those agreements. When you fill out the CME Non-Professional Certification, make sure you select No as a Non-Professional. Let us know here when you have this done. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
