Date/Time: Mon, 29 Apr 2024 16:15:21 +0000
Ver 2070 - Denali
View Count: 522
[2020-03-25 13:01:34] |
NRGTrader - Posts: 351 |
If I am subscriber to Denali data AND and not using SC for order entering, can I somehow disconnect GAIN account completely from SC and still have Denali update charts realtime? Currently data/trader service set to GAIN with allow other data services checked. I am receiving SC data feed from Denali.
[2020-03-25 19:43:19] |
Yes, you can disconnect from GAIN and still have the Denali feed functional. Just be aware that you will still need to connect to your Gain trading account once a month in order to qualify for the lower priced Non-Professional CME Exchange fees. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Also be aware that when you first switch to SC Data - All Services from GAIN, you will need to change your symbols by selecting Edit >> Translate Symbols to Current Service. Refer to the information here: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-25 19:54:58] |
1. I presume the first step means connect Gain to Sierra Chart, correct? 2. Will the second step, which BTW I already completed for Denali, need to be completed each time AFTER I connect Gain to Sierra on a monthly basis (assuming the answer to #1 is "yes"). Thank you |
