Date/Time: Fri, 03 May 2024 22:14:46 +0000
sierra not responding
View Count: 436
[2020-03-18 15:36:13] |
User865492 - Posts: 19 |
once again I am having the same issue as I did yesterday. I tried the remedies as posted previously but to no avail. this is becoming annoying, is there anyway to repair this permanently. thanks hector |
[2020-03-18 15:50:00] |
sierra error.PNG / V - Attached On 2020-03-18 15:49:51 UTC - Size: 90.81 KB - 193 views |
[2020-03-18 17:25:28] |
We apologize for the delay. Refer to our response here about this: Once again data not working Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-18 18:04:45] |
Also we can see from your screenshot, that you are running custom studies. So the most important step is to run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode And be sure to read our response above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
