Date/Time: Sun, 04 Oct 2026 16:25:59 +0000
Once again data not working
View Count: 950
[2020-03-18 16:34:43]
User865492 - Posts: 19
once again I am having the same issue as I did yesterday. I tried the remedies as posted previously but to no avail.
this is becoming annoying, is there anyway to repair this permanently. thanks hector
imagesierra error.PNG / V - Attached On 2020-03-18 16:34:31 UTC - Size: 90.81 KB - 375 views
[2020-03-18 17:20:42]
This is not a data feed issue at all. This is an issue based upon what you are doing in Sierra Chart, where there is a freezing condition. Are you running any custom studies?
We have prepared this video about this kind of problem:
https://www.sierrachart.com/Videos/Improving_Sierra_Chart_Performance.mp4
Once again this is not a data feed issue. It is in relation to your Sierra Chart configuration in regards to charts and studies and other things.
Also refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart
The first thing that we want you to do is to close your existing Chartbook, and start with a new one. There is something about the configuration and studies you are using which is causing a problem.
Date Time Of Last Edit: 2020-03-18 17:26:18
[2020-03-18 17:50:19]
Also refer to this section:
Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading
And be sure to refer to our post above.
