Date/Time: Sat, 04 May 2024 15:24:16 +0000
How To Tell If my Broker Is Connected
View Count: 567
[2020-02-06 12:44:53] |
User597941 - Posts: 6 |
I just got an account with AMP Global and Sierra Chart. Is there an easy way to tell if SC and AMP are connected appropriately? It seems like I'm getting delayed data, so I'm not sure if I'm just connected to the SC default delayed data feed. Is there a way to confirm everything is working properly? Thanks! |
[2020-02-06 18:26:47] |
What Trading service are you using with AMP? Our information shows that your Data/Trade Service Settings are set to SC Data - All Services, which is why you are only getting the Delayed Streaming Data. In the end, we recommend using this service for Order Routing: Sierra Chart / Trading Technologies Futures Order Routing Service And then you would use that with this data feed: Denali Exchange Data Feed Or they may have set you up on CQG? If so, refer to: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-06 18:27:25
