Date/Time: Mon, 29 Apr 2024 14:32:59 +0000
Chart Trading
View Count: 573
[2020-02-03 23:55:28] |
Stupid - Posts: 30 |
How do you set up the trading account and routing on the chart or the DOM and I dont see time and sales on the quoted board
[2020-02-04 11:15:30] |
Refer to the instructions here and follow step 9 and 10: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-04 12:20:44] |
i am having issues with it I have an extra line It says "intraday Download interval for Non-real Symbols (min)" this is set to 0 and I click "DTS Config"--- this is blank And now if i say OK the market stops moving on the charts or I dont see time and sales moving Date Time Of Last Edit: 2020-02-04 12:34:46
Private File Private File |
[2020-02-04 21:17:08] |
You do not need to do anything with those other settings. Leave the "Intraday Download Interval for Non-Real Time Symbols" at 0, and leave the "DTS Config" as blank. Select Edit >> Translate Symbols to Current Service: Edit Menu: Edit >> Translate Symbols To Current Service After that, let us know if you are still having a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
