Date/Time: Tue, 14 May 2024 14:44:47 +0000
Connecting TT data feed to Sierra Charts
View Count: 1920
[2019-11-27 13:36:28] |
bootsy - Posts: 63 |
I read this post FIX Services Only Allow One Connection at a Time I trade through a broker/clearing firm with their feed routing through Trading Technologies (TT) charts and DOM for market entry. Is this what you mean by by "Currently we use FIX for TT, FXCM, Currenex." Or are they just brokers? I am still unclear whether I can use my broker feed, which is not listed in your broker list, to connect to Sierra Chart as I might have the terminology all wrong. I am also on a 32 bit machine which I am aware is no longer having new versions released. Am not concerned about data feed cost, I just want to replicate my broker/CME feed onto SC charts. Regards, Bootsy |
[2019-11-27 14:48:08] |
The easiest and most reliable way to use TT is to use this new Sierra Chart order routing service: Sierra Chart / Trading Technologies Futures Order Routing Service We do not recommend using the TT data feed directly and we do not provide technical support for that. Who is your clearing firm? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-27 14:48:27
[2019-11-27 16:03:25] |
Hi there, Thanks for the quick reply. My broker is https://www.fct.com/service/#servicearchive29 R.e. not recommending TT for SC, is that a simple compatability issue? No problem if so, software is complicated let alone when exchanges and data feeds get involved. Regards, Bootsy |
[2019-11-27 20:48:46] |
SC Support - Posts: 1801 |
Maybe I can give you a call to speak about this?
[2019-11-28 03:17:43] |
TT is certainly fully supported for order routing, we just do not recommend using the data feed from TT. When we say data feed, we are referring to the market price data feed. The only complication of course is that you may have to pay exchange fees twice if you are using another program for order entry using the TT data feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-28 03:18:01
