Date/Time: Mon, 06 May 2024 22:26:03 +0000
display subgraph values on chart
View Count: 1013
[2019-11-22 14:25:35] |
Tariq - Posts: 16 |
I have two charts #1 and #2. They are suppose to be identical. They both use a spreadsheet to display a column value in the chart. Chart #1 does show the values but not chart #2. I've compared all the setting that I could think of but not able what is stopping chart #2 to display the values. Any help is appreciated. I will attach the chartbook and spreadsheet.
Chartbook1.Cht - Attached On 2019-11-22 14:23:27 UTC - Size: 86.96 KB - 283 views DefaultSpreadsheetSystemAlertStudy.scss - Attached On 2019-11-22 14:24:11 UTC - Size: 59.55 KB - 226 views |
[2019-11-23 04:15:53] |
In the chart where they are not showing (Chart # 2), you need to set the Subgraph Draw Style and the Scaling to be the same as they are in Chart #1. That means setting the Subgraph Draw Style to Value of Subgraph and setting the scaling to Constant Range. You may need to reset the scales after making the change to ensure that the numbers are displayed correctly. Refer to the following for the Subgraph Draw Styles: Chart Studies: Subgraphs Tab >> Draw Style Refer to the following for the Scales: Chart Scale and Scale Adjusting: Scale Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-25 19:27:03] |
Tariq - Posts: 16 |
Not sure what it was but when I reopened the Chartbook today. I don't see the spreadsheet study being referenced. After adding and tweaking the setting the values show up. All good now.
