Date/Time: Sun, 05 May 2024 13:42:17 +0000
Change to Sierra Chart
View Count: 728
[2019-10-14 15:40:38] |
User680631 - Posts: 3 |
Hi, so I am looking for the Symbol for the DAx Future of the DTB Gemrany. IQ Feed symbol is XG but thats not even on the symbol list you offer,...... (1)How can I find that? (I downloaded Sierra and would need some Instuctions how to proceed) (2) I also want to overlay 2 indicators in one sub-window which does not work at all. They are in the same wo Dow but one obove the other. I don't see anything to do it. This is essential for me. (3) I want to overlay 2 Indicators RSI+Williams. How does that work, tehre is nothing to be seen in the settings. (4) and where do I find the indicators please? Thank you! I just want to get into the software perfectly and then change to sierra from Ensign windws. Would be great if you coul help me to get started easier. I ave a lot of more questions, do you have a chat may to zalk over some things? Thx Michael |
[2019-10-15 12:50:03] |
1. You will find the XG futures symbols listed in File >> Find Symbol >> Futures when using IQ Feed. It is definitely there. If you want to save a lot on the data feed, use this data feed: Sierra Chart Exchange Data Feed 2, 3. Refer to: Chart Studies: Overlaying Studies in the Same Chart Region on a Chart 4. Refer to: Technical Studies Reference The most efficient way to communicate with us is through this Support Board. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-15 12:51:05
[2019-10-21 11:39:00] |
Thanks a lot. How does the additional Langugage file work. I want to change it to German but the file can not be downloaded. The XML is not to open and the Excel file does not work.
