Date/Time: Wed, 01 May 2024 02:23:37 +0000
Opening minute high/low/open extended lines through footprint chart
View Count: 1049
[2019-10-13 15:50:18] |
User283743 - Posts: 38 |
I'm using a 30 minute footprint chart for ES. What I am trying to achieve is have lines extending through the developing footprint of the first minute's RTH trading (9.30-9.31) high/low/open. I've been only partially successful using these two studies: OHLC-Variable period and High/Low for Time period. Im basing the studies on a 1 min ES chart, which seems to be whats required, but it fails to display the particular one minute period I'm after.(Instead for some reason I'm getting the 9.59-10.00 period values displayed, although the settings as far as I can see, do in no way indicate that particular time period) For ease of reading I am not including the settings of the studies, but my guess is this is where I am going wrong. Please advise. Thank you. |
[2019-10-15 15:43:48] |
John - SC Support - Posts: 31240 |
You need to use the High/Low for Time Period - Extended on the 1 minute chart and then use the Study/Price Overlay to display that on the 30 minute Numbers Bar chart. Attached is a Study Collection that has the High/Low for Time Period setup as you need. You may need to change the Start and End times for your specific time zone. Just note that the ending time should be 9:30:59 in order to capture just the first minute and not the first and second minute. Refer to the following for how to use the Study Collection: Study Collections: Using a Study Collection Provided by Sierra Chart Support And here is the documentation for the High/Low for Time Period - Extended study: High/Low for Time Period - Extended And here is the documentation for the Study/Price overlay: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
HighLowForTimePeriodExtended.StdyCollct - Attached On 2019-10-15 15:42:16 UTC - Size: 9.4 KB - 277 views Attachment Deleted. |
