Date/Time: Thu, 02 May 2024 15:03:59 +0000
Settlement Price displayed on the Quote Board
View Count: 1313
[2019-10-11 08:49:16] |
User722856 - Posts: 78 |
Dear Sierra, I think i found a bug regarding the „settlement price“ displayed on the Quote Board. -I am using Rithmic as DataFeed. -The „settlement price“ displayed on the „Historical Chart“ is Correct and that on the Quote Board not. Please Find the Description bellow. Example for FDAX: The official Exchange settlement can be found here: https://www.eurexchange.com/exchange-en/products/idx/dax/34642!onlineStatsReload?productId=34642&productGroupId=13394&busDate=20191008
I have Screenshots of the „settlement price“ on the Quote Board from the last three days – and a comparison to the official Exchange settlement.See attached Pictures. Historical chart: http://www.sierrachart.com/image.php?Image=1570783908460.png Thanks. Best regards Date Time Of Last Edit: 2019-10-11 08:52:14
settlement.png / V - Attached On 2019-10-11 08:46:23 UTC - Size: 120.34 KB - 576 views settlement_2.png / V - Attached On 2019-10-11 08:46:29 UTC - Size: 113.93 KB - 580 views settlement_3.png / V - Attached On 2019-10-11 08:46:34 UTC - Size: 113.2 KB - 372 views |
[2019-10-11 20:36:46] |
This is a data feed issue. That particular field comes from Rithmic. We do not provide technical support for Rithmic. We definitively are not going to provide further support for Rithmic. We have formally delisted Rithmic from our website. The settlement price in a historical Daily chart is from a completely different source. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-11 21:49:56
[2019-10-12 11:35:20] |
Most likely Sierra Chart is using the last trade price from Rithmic rather than the settlement price. But this is not something we are able to change for technical reasons. The integration to Rithmic is no longer being maintained. In its current state, users should begin to migrate off of Rithmic in the coming months. We have a new TT based order routing service available, there is CQG, and we are also working on a new provider for our order routing service. We have a new high-quality data feed available: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-12 11:35:38
[2019-10-12 19:46:01] |
User519919 - Posts: 6 |
Hello, what is with TopStep-Trader, is this available anyway? Because they use Rithmic as DataFeed. best regards Christian |
[2019-10-12 20:28:19] |
Rithmic can always be used, but we just have to be honest with our users, that the connection is not maintained and we do hear about problems. If you want to use Top Step Trader you can use it with Rithmic. That will always be available. We will never withdraw support for Rithmic. We just do not want to formally refer users to Rithmic. This is not meant to speak poorly of Rithmic in any way. The problem lies between the integration between Sierra Chart and Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
