Date/Time: Fri, 03 May 2024 04:58:42 +0000
Trading ES through Interactive Brokers while using Data from SC
View Count: 1012
[2019-10-07 14:37:06] |
User342873 - Posts: 2 |
I am trying to setup SC to trade through interactive brokers. I have it set to the SC data feed and trading through IB and it auto logs me in to IB when I open SC. I can pull up an account window summary and it shows my IB account connected. However, whenever I turn off simulation mode to trade and i enter a trade on the DOM it immediately enters it back in simulation mode. I can't select my account from the dropdown list on the DOM control panel. I have also changed the symbol for trade only mode to the correct symbol for IB. (ES is different for IB vs sierra chart).
[2019-10-08 02:57:34] |
You need to follow the instructions in this section here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services (Integration with Trading Services) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-08 02:59:39
[2020-05-10 09:47:56] |
User111911 - Posts: 8 |
I am trying to connect Sierra Chart to an Interactive Brokers paper trading / simulation account to ensure that connectivity works well before I switch to live trading. I followed the steps listed and the account is connected. I have also ensured that "Allow Support for Sierra Chart Data Feeds" box is ticked and followed through with "Translate Symbols to Current Service". I get the following error messages: (1) "Symbol Settings not found for symbol. Unable to build continuous futures contract" (2) Historical data not subscribed for (this message is from IB) - I shouldn't be getting this message since I am using Sierra Chart Data Feeds. Kindly help. Thank you. |
[2020-05-12 00:58:14] |
Tell us the symbol of the chart. It sounds like you are not using the correct symbol.
