Date/Time: Sun, 05 May 2024 09:05:03 +0000
FO Futures Contracts Are NOT 2020 Ones
View Count: 609
[2019-09-27 15:14:42] |
MichaelPPTF - Posts: 55 |
Hello, Would love to know how to get futures quotes/charts up for 2020 symbols. Platinum has already rolled to F20 but Sierra can only do "PLF0" which shows up as Jan 2010. *EDIT: I put in PLF0 and it pulls up PLF10 instead of F20 Date Time Of Last Edit: 2019-09-27 15:36:51
[2019-09-27 15:21:06] |
User90125 - Posts: 715 |
Try "PLF0" .
[2019-09-27 16:02:30] |
In regards to post #1, this issue has been resolved and you need to update Sierra Chart to the latest version and that latest version does support trading with Transact. Instructions: Software Download: Fast Update So there is no problem with updating and you are far better off. The websocket connection at this point in time is far more reliable than the bridge. But if you do have any trouble connecting to Transact after updating , do refer to: https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccountLogonError Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-27 16:03:27
