Date/Time: Sat, 04 May 2024 02:43:10 +0000
recommended futures broker
View Count: 2396
[2019-09-05 16:30:18] |
User735389 - Posts: 188 |
is interactive brokers the currently recommended futures broker for sierrachart? Their page: https://www.sierrachart.com/index.php?l=doc/InteractiveBrokers.php has a number of disclaimers. I'm not sure if you guys are just covering your bases or if you guys run into issues with them somewhat regularly.
[2019-09-05 19:51:46] |
We normally do not make recommendations. What particular futures exchanges do you want to trade on? Interactive Brokers is good if you need to trade lots of different types of securities. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-05 19:52:11
[2019-09-10 01:52:45] |
primarily cme. maybe ice and comex. not necessarily looking for a recommended broker, but broker(s) that are well supported and have exhibited reliability with sierrachart.
[2019-09-10 10:54:07] |
Have a look at using this service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
