Date/Time: Fri, 03 May 2024 04:25:24 +0000
radu pop
View Count: 678
[2019-09-02 16:42:40] |
User749229 - Posts: 7 |
hello i am using Tradovate as a broker and i am using sierra charts for charting but i do need live data feed for micro ES500 cntract ,my question is can you provide the data or do i have to connect my broker to sierra chart?
[2019-09-03 03:46:23] |
You can use this data feed: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* However, before using that data feed be aware of the following:: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-03 03:47:25
[2019-09-04 00:10:33] |
Sierra Chart - Max - Posts: 5599 |
From User: hello there you are realy not helping , i just want to know if i can get live data feed as i need the TPO profile for Micro ES or do i have to go with my broker, my broker asks extra 15 usd / month plus 0.19 /contract for CQG data feed
Sierra Chart Support |
[2019-09-04 00:51:48] |
SC Support - Posts: 1797 |
Do you have a minute to speak about this?
[2019-09-04 08:04:02] |
It will definitely be cheaper to access the data feed through your broker.
