Date/Time: Mon, 29 Apr 2024 02:49:46 +0000
clarification please
View Count: 745
[2019-08-29 18:40:37] |
User734688 - Posts: 23 |
I am an Infinity client. Due to problems with the Transact Feed, Denali Feed was "trialled". I wish to continue with the Denali Feed, but am not sure how to complete the Forms. Do I have to choose a Service Package (since I am an Infinity client0? The Exchange Agreement asks for Trading Account No., Clearing Firm, and Salesperson. I imagine I am to write the Number of my Infinity Trading account, and I don't know who Infinity clear through??? I also imagine that once I have done these Forms I can choose which Data Feed I desire?? Thanks, |
[2019-08-29 18:55:16] |
SC Support - Posts: 1795 |
We can help you with this, can I give you a phone call?
[2019-08-29 19:24:36] |
You should first try Prerelease version 1982 in September and see how the Transact data feed works and see if you still notice a lag. Here are the instructions to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-29 19:26:13
[2019-08-30 03:31:28] |
I am unavailable to remedy this, but my business partner (Peter O'Connor) is available. So, I give permission for you to call him and provide him with the instructions to set up the account. His number is Australia ** Actually, it is my preference that you call him to provide instructions, then it will only take me a second when I get to the office to set up. thanks, Elena Date Time Of Last Edit: 2019-08-30 06:29:09
[2019-08-30 06:27:08] |
There can be no doubt at all, that you have a problem with your Internet connection. You are not receiving data for a period of time from four different servers of ours in different data centers and geographical locations: SC Data - All Services | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2019-08-29 15:34:50.511
SC DTC Data with Market Depth | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2019-08-29 15:34:47.999 You will need someone to look into this on your side. This is not going to be within the scope of our support. ESU9 1 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2019-08-07 18:43:00. Next Bar Date Time: 2019-08-07 18:18:00. Filename: ESU9.scid | 2019-08-29 08:49:20.687 We also notice this. This may be from the time you were using Transact data. Follow the instructions below:Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-30 06:28:15
[2019-09-03 13:45:42] |
I've had the prerelease version installed and already I can see that the Transact feed it not the same as the Infinity DOM. The Transact Feed is often 2-3 ticks away from DOM and sometimes it just hangs without new data. Could someome call me on Australia 0435515536 to advise me on subscribing to Denali please. Thanks, Elena |
[2019-09-03 14:06:34] |
if someone could call me as a matter of important please... I cannot trade without accurate data... I have screen shots if you like to show the difference between DOM and Charting.
[2019-09-04 02:55:54] |
We apologize for the delay here. You will need to use the Denali exchange data feed. Here are the set up instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* We will see if anyone called yet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-04 13:57:57] |
Called and talked to customer and got them setup on the Denali feed.
