Date/Time: Sat, 18 May 2024 22:45:44 +0000
Spread Charts
View Count: 2128
[2019-08-27 04:18:36] |
flowtra8r - Posts: 10 |
I am trying to pull Spread charts like ES/ZB, Gold/Copper etc. How can I do that on SC?
[2019-08-27 18:09:21] |
If these are exchange traded spreads, then they would be available on the Find Symbol window. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Exchange Traded Spreads Otherwise, if you are wanting to create these spreads yourself in Sierra Chart, then there are different methods of doing this. One method is documented here: Custom Calculated Symbols Or refer to: Add Additional Symbol Difference (Bar or Single Line) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
