Date/Time: Sat, 27 Apr 2024 22:51:31 +0000
Version
View Count: 1619
[2019-08-12 21:01:21] |
John Ara - Posts: 125 |
I have updated my sierra but don't know what version I was using. I appreciate if you let me know my last version? Thank you. |
[2019-08-12 21:52:55] |
Ackin - Posts: 1865 |
In Sierrachart check: Menu >> Help >> About edit: Sorry, only current version, I overlooked "my last version" Date Time Of Last Edit: 2019-08-12 22:31:42
[2019-08-12 21:57:35] |
Please let me know the one before if your system shows.
[2019-08-12 22:28:09] |
For a particular installation of Sierra Chart there is not a way to know what version you were previously running.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-12 22:28:16
[2019-08-12 22:58:15] |
User90125 - Posts: 715 |
Unless you have saved your previous message log, that is. Presuming that Sierra does not overwrite saved logs upon version update. Go to Global Settings >> General Settings >> General 2 and Save Message Log to File. More info here: General Settings Window: Save Message Log to File (Global Settings >> General Settings >> Log >> Log) |
[2019-08-12 23:08:01] |
I have my log file which says version 9 but this number is odd since my current version is 1971.
[2019-08-13 01:57:19] |
Yes that is true, you could look at the main Message Log. We did not think about that. If you see version 9 that must be the installer log. Not the main Sierra Chart program Message Log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-13 01:57:35
[2019-08-13 19:44:07] |
Please let me know how I may downgrade to version 1869?
[2019-08-13 20:03:23] |
Follow the instructions here: Software Download: Software Rollback Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
