Date/Time: Sun, 05 May 2024 16:32:56 +0000
Tick-Nyse data
View Count: 534
[2019-08-09 16:19:37] |
User63428 - Posts: 2 |
Hi, I want to have a TICK-NYSE chart up and running but the last day a can recieve is Januari 14th 2019. Why can't I recieve the latest Tick data? Regards, Henry |
[2019-08-09 17:22:14] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings If you still have a problem then follow the instructions below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
