Date/Time: Sun, 28 Apr 2024 13:35:20 +0000
Email alerts
View Count: 2053
[2019-08-01 05:33:13] |
User27542 - Posts: 20 |
Can you please let me know how to receive an email once a price level has been crossed? Presumably I can put a horizontal line at the appropriate level on the chart and then set an alert for that line. Is that right? With thanks for any help you can give
[2019-08-01 07:43:33] |
You can do this through the Symbol Alert functionality. Refer to: Alerts Manager: Symbol Alerts To setup email notifications, refer to: General Settings Window: E-mail Notifications for Alerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-18 17:48:22] |
User353062 - Posts: 26 |
How can I disable email alerts for SIM trading?
[2020-10-19 04:26:56] |
We need to know what specific alerts you are referring to and what is generating them.
[2020-10-19 15:08:54] |
Here is the screenshot.
[2020-10-19 16:04:10] |
In this case you just simply set that setting to "No Alert Sound" if you do not want to use it. This is all.
[2020-10-19 16:22:05] |
Then how to get email alert for live order fill-in not sim trades?
[2020-10-19 19:14:49] |
You will need to use that particular alert setting for the email alert message. Here is the documentation for configuring email alerts associated with specific Alert Numbers: General Settings Window: E-mail Notifications for Alerts And then probably will want to use a sub instance for simulated trading: Using DTC Server for Data and Trading in Another Sierra Chart Instance And configure that sub instance to not use any order related alerts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-19 19:15:07
