Date/Time: Thu, 09 May 2024 03:54:52 +0000
CQG
View Count: 758
[2019-07-30 18:58:17] |
John Ara - Posts: 125 |
There are two cqg connections used on MY sierra chart 1) sierra chart (fix vendor), 2) Sierra Chart Data needed for system. Image is attached. Please let me know which cqg connection I need? Thank you. Date Time Of Last Edit: 2019-07-31 04:41:38
Private File |
[2019-07-31 08:37:18] |
In your case you will need to use CQG FIX. Also be aware of these new services: Sierra Chart / Trading Technologies Futures Order Routing Service Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
