Date/Time: Sat, 11 May 2024 16:04:36 +0000
Does Sierra Have a control panel on the chart that can take off overlay correlations?
View Count: 1795
[2019-07-27 14:31:14] |
User301475 - Posts: 8 |
Does Sierra have something Similar to Tradingview/Investing.com where with a click of a button on control panel on the top left corner of the chart you can take off Overlays and Correlation Spreads created on the chart without having to go to Studies to Hide each correlations? I attached a picture of what it looks like on image where a click of the 'eye' icon would take off/on each correlations. Is there any studies on Sierra That can do this? I would be most grateful if there was such a study as it would add soo much convenience in taking on/off correlations to compare, Thanks very Much!! |
Attachment Deleted. Control Panel Investing-Tradingview - Sierra Chart.PNG / V - Attached On 2019-07-27 14:29:08 UTC - Size: 440.6 KB - 345 views |
[2019-07-27 16:46:41] |
John - SC Support - Posts: 31534 |
On the Analysis menu there are the commands: Hide All Studies and Unhide All Studies. Refer to the documentation starting here for these: Analysis Menu: Hide All Studies Second, as noted in that documentation, you can create Control Bar Buttons and/or Keyboard Shortcuts for those menu options. You will find the links to how to do those in the documentation referenced above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-28 00:40:07
[2019-07-27 23:14:14] |
Also refer to: Chart Studies: Hiding and Showing Study Directly from Chart (Hiding and Showing Study Directly from Chart) This is probably more what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-28 00:48:37] |
Great John & SC Engineering, Thanks for feedback, got some ideas & I can work some ideas with this!! Keep up the great work!
