Date/Time: Thu, 09 May 2024 05:36:10 +0000
spread chart question
View Count: 1328
[2019-07-26 14:02:40] |
User450179 - Posts: 105 |
I was wondering if i might have found a work around for the high accuracy spread chart, but it isn't working all that great but I was hoping you might have a work around for me. 1. i opened 2 charts. crude oil october and crude oil december 2. I used the difference study to get a spread chart. I am 1 minute interval 3. I used duplicate chart and got my main chart with spread chart duplicated. 4. I changed teh original chart (difference study) to 10 seconds 5. I changed the duplicate chart to 1 minute. is the duplicate chart building 1 minute bars off of 10 second data? I feel like it should be but for some reason the spread chart actually has all the bars per minute but they are not the correct range. do you have a work around for this possibly because for some reason this way is easier for me to understand. when i change both the duplicate and the orignal to 1 minute they chart with the correct range but obviously not high accuracy. thank you NEW QUESTION just thought it mit make this faster. 1. market if touched orders being traded from the chart. 1. I am wondering why I cannot slide (change price) of an MIT order like I can limit orders and stops? is this possible for you to implement in your next update? basically I place an MIT order and if i want to change the price I just move the order or slide it to a new price and release the mouse for the new order price just like I can do with limits and stops. thank you |
[2019-07-26 17:41:14] |
John - SC Support - Posts: 31480 |
There are a couple of ways you can do this, but refer to the following for one way to do this: How to Create High Accuracy Spread or Ratio Charts With regards to the Market if Touched, you can select the order and move it with the pointer. We do not know why you would have any issue with this. Try it out in Simulation mode with just the single order and no attached orders. Make sure the price is set lower than the current market for a Buy order or higher for a Sell order. Refer to the information on this order type here: Order Types: Market If Touched For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-27 00:54:29] |
In regards to high accuracy spreads really the best way to do this currently is what is documented here: Custom Calculated Symbols And historical data support for when not connected to the data feed will come as soon as we can do this. Use the Market if Touched-Client order: Order Types: Market if Touched - Client We are going to remove support for Market if Touched orders with Gain Capital because clearly they are not working properly. You will need to use the client-side one instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-27 00:57:14
