Date/Time: Sun, 19 May 2024 00:53:43 +0000
Service Package 5 - Platform Subscription
View Count: 2019
[2019-07-03 16:19:54] |
Oxcap - Posts: 55 |
Hello SC Support, I am looking into paying for a package 5 subscription for three (3) months to test out. I have a few questions to help understand the process if you can kindly reply. First, a few things to give you an idea of my trading platform/connections. I trade only the ES and NQ. I use NinjaTrader8 (NT8) as my execution platform with CQG data feed. In addition, I also use TD Ameritrade. Questions: 1) If I'm running TD Ameritrade, can I use the futures data feed to connect to SC to receive real-time futures data. 2) If No to Question 1 above, can I connect SC with my current CQG data feed from NT8 to receive real-time futures data. 3) If NO to above Question 1 + 2, then could you provide a monthly quote for how much it would cost for Package 5 + CME (ES/NQ) live data feed Thank you, |
[2019-07-03 16:46:19] |
1) If I'm running TD Ameritrade, can I use the futures data feed to connect to SC to receive real-time futures data. Yes. This is the data feed you need to use:Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-03 16:52:27] |
Oxcap - Posts: 55 |
Is using CQG with my current connection with NT8 an option as well?
[2019-07-03 18:20:15] |
Yes but there are complications with that. Refer to: Using Sierra Chart with Ninja Trader Brokerage Although it can be done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-03 23:21:06] |
Oxcap - Posts: 55 |
Ok. Since there are complications, I will not use CQG data. Now I'm trying to understand the data feed process. So if I want to use SC and receive live futures data then I would need to sign up for Denali Exchange Data Feed which is $30/monthly. IN addition to signing up for Denali Exchange, I would also need to active exchange for CME with Market Depth for non professional trading accounts for $5.25/monthly. Is that Correct? Denali Exchange $30 + Exchange Activation $5.25 = $35.25/monthly Is that correct? Thanks |
[2019-07-04 01:35:30] |
Denali Exchange $30 + Exchange Activation $5.25 = $35.25/monthly Is that correct? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-04 03:04:48] |
Oxcap - Posts: 55 |
Ok thank you. So then basically Denali + activation would not require TD Ameritrade right? This connection would be independent? Also, I noticed this subscription allows up to 2 computer systems? I have 1 desktop at home and another at second location. Would both be able to use simultaneously? |
[2019-07-04 17:10:23] |
Sierra Chart - Max - Posts: 5618 |
1. You would need to have Trading Account with a Supported Trading Service, such as TD Ameritrade. 2. Yes, you would be able to use it from both computers. Sierra Chart Support |
