Date/Time: Mon, 29 Apr 2024 05:47:28 +0000
trouble downloading symbol data
View Count: 959
[2019-06-25 19:39:19] |
bskogz12 - Posts: 36 |
for some reason historical data is not downloading, is there a reason for this, maybe a setting i applied by mistake
[2019-06-25 19:58:18] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-25 20:13:24] |
this screen shot might help
Attachment Deleted. |
[2019-06-25 20:58:37] |
No, that is not helpful. Please follow the instructions in post #2.
[2019-06-25 23:35:33] |
Intraday chart data file opened for SSO | 2019-06-25 19:32:10 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2019-06-25 19:32:10 Still not downloading, just says download failed and this is whats in the message |
[2019-06-26 01:50:30] |
This is definitely not helpful. We need to see the entire Message Log. Follow the instructions below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-27 20:05:36] |
I sent the analysis of the message log just a moment ago
[2019-06-28 14:23:24] |
We see you are using IQ Feed. We want you to do two things. Update to the latest IQ Feed software: http://www.iqfeed.net/index.cfm?displayaction=support§ion=download And update to the latest Sierra Chart version: Software Download: Fast Update After that: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
