Date/Time: Sat, 04 May 2024 17:07:29 +0000
Continuous contract volume
View Count: 586
[2019-06-25 18:42:19] |
grantx - Posts: 244 |
How do I load up all the daily volume for the past year? See screenshot. Volume doesnt go back very far. Alternatively. How do I download this daily data (including the volume data) into your spreadhseet chart? |
2019-06-25_19-39-34.png / V - Attached On 2019-06-25 18:41:57 UTC - Size: 34.06 KB - 238 views |
[2019-06-25 19:55:51] |
You need to make the chart a Continuous Contract chart. Refer to the documentation here for this feature: Continuous Futures Contract Charts To get the data in a spreadsheet, the easiest thing to do is to just add a Spreadsheet Study to the chart, and the data is automatically loaded into the initial columns. But, depending on what you want to do with the data, you may need just an independent spreadsheet, in which case, just copy the columns you want and open a new spreadsheet by selecting File >> New Spreadsheet and then paste the data into that spreadsheet. Refer to the following for the Spreadsheet Study: Using the Spreadsheet Study And refer to the following for independent spreadsheets: Working with Spreadsheets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-25 19:56:56
