Date/Time: Mon, 06 May 2024 15:54:09 +0000
Tick chart related questions
View Count: 660
[2019-06-24 20:32:53] |
inner_silence - Posts: 9 |
Hello, I am running a triall of Sierra Charts and have a following questions: 1) I like to run tick-by-tick and minute-based charts in parallel. Is it possible to do with your charting platform? I saw "intraday data storage time limit" setting which lets me choose TICK. Does it affect minute-by-minute charting? 2) The real-time data feed you provide, is it unfiltered? I am currently interested in US CFDs. 3) Do you support auto-liquidation? 4) I was playing with studies (RSI) and noticed I couldn't change the line color. Is it possible to change the line color and width? tx |
[2019-06-25 02:22:34] |
1. Yes. Just configure the Chart Settings as required for each chart. You can also use two separate instances of Sierra Chart, one of them can store data in one minute units and the other one tick by tick. Refer to: Changing Chart Bars Period: Improving Performance of Loading Chart Data Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration 2. Yes. 3. Yes. 4. Yes: Chart Studies: Subgraphs Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
