Date/Time: Sun, 28 Apr 2024 21:22:12 +0000
BitMEX daily/open close variance
View Count: 655
[2019-06-15 20:40:48] |
User116783 - Posts: 84 |
Hello, I noticed that the sierra chart daily open/close values for XBTUSD are different than on the BitMEX itself. The proper open should be at 20:00 and close at 19:59. ZS Date Time Of Last Edit: 2019-06-15 20:53:48
[2019-06-16 00:10:15] |
I was able to correct this issue by using intraday data only and changing the chart session time: Chart Session Times: Creating Daily Bars with Custom Session Times There is however still one very minor issue. The opening time for 2019-06-14 is 1 tick off. I confirmed this by examining the open of the 20:00:00 1 min bar, and comparing it to the same bar at the BitMEX. There was a 1 tick discrepancy, with the BitMEX showing an open of 8695.00 and Sierra Chart 8695.50. ZS Date Time Of Last Edit: 2019-06-16 00:13:21
[2019-06-16 22:59:41] |
How do you change the weekly open for XBTUSD to Monday instead of Sunday? Thx ZS |
[2019-06-17 04:04:25] |
This is explained here: https://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#HistoricalDailyData Refer to this particular setting: General Settings Window: Use Monday as Start of Week instead of Sunday (Global Settings >> General Settings >> General >> Data) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-17 04:04:33
