Date/Time: Thu, 02 May 2024 23:56:32 +0000
no streaming charts 2nd instance
View Count: 926
[2019-06-13 18:02:10] |
cmb999 - Posts: 211 |
log: HD Request # 11 | Downloading Intraday chart data for YMU19 to the file YMU19.scid. Service: cbot | 2019-06-13 13:59:10.649 HD Request # 11 | Download start date-time: 2019-06-13 13:47:00.000 | 2019-06-13 13:59:10.650 HD Request # 11 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2019-06-13 13:59:10.649 Socket (1) | Creating socket. | 2019-06-13 13:59:10.650 Socket (1) | Connecting to IP: 8.18.161.135. | 2019-06-13 13:59:10.650 Socket (2) | Socket gracefully closed by remote side. | 2019-06-13 13:59:10.693 Socket (2) | Closed. | 2019-06-13 13:59:10.693 HD Request # 11 | Setting DTC encoding to Binary VLS | 2019-06-13 13:59:10.749 HD Request # 11 | Sending historical data logon request message. | 2019-06-13 13:59:10.749 HD Request # 11 | Requesting Intraday data. Start date-time: 2019-06-13 13:47:00. Record interval: 60. Symbol: YMU19 | 2019-06-13 13:59:10.812 HD Request # 11 | Decompressing data. | 2019-06-13 13:59:10.863 HD Request # 11 | Receiving Intraday data for YMU19 starting at 2019-06-13 13:47:00 | 2019-06-13 13:59:10.863 HD Request # 11 | Timestamp of first Intraday data file record written: 2019-06-13 13:47:00 | 2019-06-13 13:59:10.863 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-13 13:59:10.864 Historical data download thread signaled to stop. | 2019-06-13 13:59:10.865 HD Request # 11 | Received 3 records from 2019-06-13 13:47:00.000 to 2019-06-13 13:49:02.000 (2.0 minutes) and wrote 3 records for YMU19 | 2019-06-13 13:59:10.865 HD Request # 11 | Completion time: 0s | 2019-06-13 13:59:10.870 HD Request # 11 | Intraday data download complete for YMU19. Unique request ID: 10 | 2019-06-13 13:59:10.870 Removed historical data download ID 10 | 2019-06-13 13:59:10.870 Real-time Intraday chart data file updates started for YMU19 | 2019-06-13 13:59:10.870 Opened cached Intraday file: C:\SierraChart_AMP\Data\YMU19.scid | 2019-06-13 13:59:10.870 Intraday chart data file opened for YMU19 | 2019-06-13 13:59:10.870 |
[2019-06-13 19:35:09] |
2nd computer to be more accurate (not just 2nd instance)
[2019-06-13 20:52:21] |
Right we understand. We are going to implement a solution to this in the next release to automatically allow other instances to be aware that you have a funded trading account. But now you need to connect that instance of Sierra Chart at least once a month to your funded trading account: Sierra Chart Exchange Data Feed: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-13 20:52:57
[2019-06-14 00:54:02] |
i thought that might have something to do with it. so i connected a 2nd instance on the 2nd computer to IB. i then exited out of the 1st instance on the 2nd computer connected to sc datafeed, and restarted that one. but, no dice
[2019-06-14 03:02:49] |
This is confusing. You need to connect the instance you want real-time CME data on, to your funded trading account at least once a month.
[2019-06-14 04:28:19] |
oh i see, the broker connection has to be from the same instance, not just same computer. is it possible to run real-time sc data as the only data connection from a separate instance even if broker connect on a different instance, you all would know i have broker account from other instance |
[2019-06-14 15:41:11] |
is it possible to run real-time sc data as the only data connection from a separate instance even if broker connect on a different instance, you all would know i have broker account from other instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-14 15:41:20
[2019-06-16 12:06:49] |
i have only one instance running now on 2nd pc. connection is IB, with SC data checked as historical chart datasource i want to chart and trade IB-only symbols, like nikkei mini (N225M-201909-OSE.JPN-JPY-100) however, when i do, the chart appears blank i notice in the symbol list, there is 'IB Forex (For Trading)' group, which lets you chart and trade IB-only forex products could something similar be done for IB-only futures ? |
[2019-06-17 03:51:27] |
i want to chart and trade IB-only symbols, like nikkei mini (N225M-201909-OSE.JPN-JPY-100) First check with Interactive Brokers about this. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-29 14:27:12] |
2nd instance of sierra, IB gateway 972.1t (all colors green), "allow support sierra chart datafeed" is checked, gives following message log 1st instance on different pc/location loads K200 fine, but the setting "Allow support sierra chart datafeed" is unchecked Software version: 1939 64-bit | 2019-07-29 09:59:45.923 Usage end date: 2019-08-20 | 2019-07-29 09:59:45.923 Enabled for: Advanced Features. | 2019-07-29 09:59:45.923 Enabled for: Sierra Chart Historical Data Service. | 2019-07-29 09:59:45.923 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-07-29 09:59:45.923 Enabled for exchange: INDEXES_DATA_BARCHART | 2019-07-29 09:59:45.923 Enabled for exchange: CME (Trading Account Required) | 2019-07-29 09:59:45.923 Enabled for exchange: CBOT (Trading Account Required) | 2019-07-29 09:59:45.923 Enabled for exchange: COMEX (Trading Account Required) | 2019-07-29 09:59:45.923 Enabled for exchange: NYMEX (Trading Account Required) | 2019-07-29 09:59:45.923 Enabled for exchange: Eurex with Market Depth | 2019-07-29 09:59:45.923 Enabled for exchange: S&P Indices | 2019-07-29 09:59:45.923 Enabled for exchange: Dow Jones Indices | 2019-07-29 09:59:45.923 Enabled for exchange: NASDAQ Indices | 2019-07-29 09:59:45.923 Enabled for exchange: Hong Kong Futures Exchange | 2019-07-29 09:59:45.923 Enabled for exchange: CBOT (Trading Account Required) - Dow Jones Indices | 2019-07-29 09:59:45.923 Enabled for exchange: CME (Trading Account Required) - NASDAQ Indices | 2019-07-29 09:59:45.923 Enabled for exchange: CME (Trading Account Required) - S&P Indices | 2019-07-29 09:59:45.923 Received 2 data feed usernames. | 2019-07-29 09:59:45.923 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-07-29 09:59:45.923 Current selected Data/Trading service: Interactive Brokers | 2019-07-29 09:59:45.923 Custom symbol settings values: enabled | 2019-07-29 09:59:45.923 Chart Update Interval: 200 | 2019-07-29 09:59:45.923 Intraday Data Storage Time Unit: 60 | 2019-07-29 09:59:45.923 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-07-29 09:59:45.923 2019-07-29 09:59:45 Local computer time | 2019-07-29 09:59:45.923 2019-07-29 13:59:45 Local computer time in UTC | 2019-07-29 09:59:45.923 2019-07-29 09:59:45 Local computer time in SC Time Zone | 2019-07-29 09:59:45.923 2019-07-01 12:52:46 Server time in UTC | 2019-07-29 09:59:45.923 Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-07-29 09:59:45.923 Program path: C:\SierraChart\ | 2019-07-29 09:59:45.923 Data Files path: C:\SierraChart\Data\ | 2019-07-29 09:59:45.923 OS Version Number: 10.0 | 2019-07-29 09:59:45.923 Locale Setting: C | 2019-07-29 09:59:45.923 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-07-29 09:59:45.926 Interactive Brokers | Using primary service for historical data for K200-201909-KSE | 2019-07-29 10:00:01.438 Intraday data recording state for symbol K200-201909-KSE is set to download 'Pending'. | 2019-07-29 10:00:01.438 Reloading all charts with filename: K200-201909-KSE.scid | 2019-07-29 10:00:01.438 HD Request # 10426 | Downloading Intraday chart data for K200-201909-KSE to the file K200-201909-KSE.scid. Service: interactive_brokers.trading | 2019-07-29 10:00:01.443 HD Request # 10426 | Download start date-time: 2019-06-21 20:00:00.000 | 2019-07-29 10:00:01.443 HD Request # 10426 | Requesting a total of 21 days and 0 seconds. | 2019-07-29 10:00:01.443 HD Request # 10426 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1728000. | 2019-07-29 10:00:01.443 HD Request # 10426 | Requesting 1 Day of data at 1 min with ending date-time at 2019-07-09 11:10:01 for K200-201909-KSE. PriceType: TRADES | 2019-07-29 10:00:01.443 K200-201909-KSE [C-D] 5 Min #18 | Reloading chart. | 2019-07-29 10:00:01.626 K200-201909-KSE [C-D] 5 Min #18 | Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2019-07-29 10:00:01.626 K200-201909-KSE [C-D] 5 Min #18 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-29 10:00:01.626 K200-201909-KSE [C-D] 5 Min #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\K200-201909-KSE.scid | 2019-07-29 10:00:01.645 HD Request # 10426 | Error downloading historical Intraday data for K200-201909-KSE. The download timed out. | 2019-07-29 10:03:03.105 HD Request # 10426 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for K200-201909-KSE | 2019-07-29 10:03:03.105 HD Request # 10426 | Completion time: 3m 2s | 2019-07-29 10:03:03.105 HD Request # 10427 | Downloading Intraday chart data for K200-201909-KSE to the file K200-201909-KSE.scid. Service: interactive_brokers.trading | 2019-07-29 10:03:03.105 HD Request # 10427 | Download start date-time: 2019-06-21 20:00:00.000 | 2019-07-29 10:03:03.106 HD Request # 10427 | Requesting a total of 21 days and 0 seconds. | 2019-07-29 10:03:03.106 HD Request # 10427 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1728000. | 2019-07-29 10:03:03.106 HD Request # 10427 | Requesting 1 Day of data at 1 min with ending date-time at 2019-07-09 11:13:03 for K200-201909-KSE. PriceType: TRADES | 2019-07-29 10:03:03.106 Message from IB: Historical Market Data Service error message:API historical data query cancelled: 200434. IB Error Code: 162. Request ID: 200434. | 2019-07-29 10:03:03.115 HSI-201907-HKFE [C][M] 60 Min #25 | Reloading chart. | 2019-07-29 10:05:46.512 + Chart Data Loading Thread Stopwatch: 0.014559541767119072 seconds. | 2019-07-29 10:05:46.550 HSI-201907-HKFE [C][M] 60 Min #25 | StartDateTimeForLoadingOrderFills: 2019-07-28 18:00:00 | 2019-07-29 10:05:46.556 HD Request # 10427 | Error downloading historical Intraday data for K200-201909-KSE. The download timed out. | 2019-07-29 10:06:03.121 HD Request # 10427 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for K200-201909-KSE | 2019-07-29 10:06:03.121 HD Request # 10427 | Completion time: 3m | 2019-07-29 10:06:03.121 HD Request # 10428 | Downloading Intraday chart data for K200-201909-KSE to the file K200-201909-KSE.scid. Service: interactive_brokers.trading | 2019-07-29 10:06:03.121 HD Request # 10428 | Download start date-time: 2019-06-21 20:00:00.000 | 2019-07-29 10:06:03.121 HD Request # 10428 | Requesting a total of 21 days and 0 seconds. | 2019-07-29 10:06:03.121 HD Request # 10428 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1728000. | 2019-07-29 10:06:03.121 HD Request # 10428 | Requesting 1 Day of data at 1 min with ending date-time at 2019-07-09 11:16:03 for K200-201909-KSE. PriceType: TRADES | 2019-07-29 10:06:03.121 Message from IB: Historical Market Data Service error message:API historical data query cancelled: 200435. IB Error Code: 162. Request ID: 200435. | 2019-07-29 10:06:03.122 HSI-201907-HKFE [C][M] 120 Min #25 | Reloading chart. | 2019-07-29 10:07:37.281 + Chart Data Loading Thread Stopwatch: 0.0070449152046397215 seconds. | 2019-07-29 10:07:37.294 HSI-201907-HKFE [C][M] 120 Min #25 | StartDateTimeForLoadingOrderFills: 2019-07-28 18:00:00 | 2019-07-29 10:07:37.299 HD Request # 10428 | Error downloading historical Intraday data for K200-201909-KSE. The download timed out. | 2019-07-29 10:09:03.129 HD Request # 10428 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for K200-201909-KSE | 2019-07-29 10:09:03.130 HD Request # 10428 | Completion time: 3m | 2019-07-29 10:09:03.130 HD Request # 10428 | Intraday data download complete for K200-201909-KSE. Unique request ID: 8190 | 2019-07-29 10:09:03.130 Removed historical data download ID 8190 | 2019-07-29 10:09:03.130 Real-time Intraday chart data file updates started for K200-201909-KSE | 2019-07-29 10:09:03.130 Opened cached Intraday file: C:\SierraChart\Data\K200-201909-KSE.scid | 2019-07-29 10:09:03.130 Intraday chart data file opened for K200-201909-KSE | 2019-07-29 10:09:03.130 Message from IB: Historical Market Data Service error message:API historical data query cancelled: 200436. IB Error Code: 162. Request ID: 200436. | 2019-07-29 10:09:03.132 |
[2019-07-29 18:30:54] |
This is the relevant message: HD Request # 10426 | Error downloading historical Intraday data for K200-201909-KSE. The download timed out. | 2019-07-29 10:03:03.105 We cannot help with this. You need to contact Interactive Brokers about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-29 18:31:06
[2019-09-03 14:53:55] |
i let lapse sc datafeed renewal by a few hours. renewed it today, 2nd instance does not stream real-time updates |
[2019-09-03 15:40:38] |
This has been corrected. It was an exchange authorization issue for your second Barchart account. Being you just require CME data, next month use the Denali Exchange Data Feed which will avoid this kind of problem to begin with: Denali Exchange Data Feed Since there is no involvement with Barchart or their authorization system with that data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
