Date/Time: Fri, 24 May 2024 06:57:13 +0000
number bars study - how to set up like footprint chart
View Count: 4251
[2019-06-03 16:30:01] |
Kyle Alan Anderson - Posts: 2 |
i want to set up the number bars study so it looks like a footprint chart that shows the amount bought and sells per bar to be able to see the order flow. I was looking for something like this to be the final outcome. If there is a study already created for this please let me know. Thank you for your help Date Time Of Last Edit: 2019-06-03 16:57:06
footprint.PNG / V - Attached On 2019-06-03 16:56:32 UTC - Size: 61.29 KB - 1071 views |
[2019-06-03 17:17:17] |
if i could get it set up as in the picture would be great.
[2019-06-04 15:22:02] |
John - SC Support - Posts: 31856 |
Attached is a Study Collection that has a very basic Numbers Bars study in it to help get you started. The Numbers Bars is set to display the Bid x Ask totals for each bar and price along with coloring the bar based on the Total Volume. You would just need to change the colors to match the image you provided. Here is the documentation for how to use the Study Collection file we provided: Study Collections: Using a Study Collection Provided by Sierra Chart Support You will find the documentation for the Numbers Bars study here: Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
NumbersBars-BidxAsk-TotalVolumeColoring.StdyCollct - Attached On 2019-06-04 15:21:57 UTC - Size: 9.52 KB - 705 views |
