Date/Time: Sat, 04 May 2024 16:40:22 +0000
Horizontal Line on Trade DOM
View Count: 2005
[2019-04-16 16:50:09] |
seandunaway - Posts: 213 |
Will you please enable the Horizontal Line tool on the Trade DOM? I can use a few other tools there, but Type Text drifts left as the (invisible) bar period progresses. I know I can add a line via Studies, but that's a tedious process in the heat of the moment. Thank you for your consideration! |
[2019-04-16 17:51:50] |
This will be added for the Trading DOM in the next release. In the meantime, you mention the Type Text option, but that it moves. There is also the Stationary Text Drawing Tool which you can access from the Trading DOM chart menu. This will not move and we verified that. It can also be tied to the Price level at which it is drawn (it will move up and down with the prices, but not left and right with the time). Refer to the information on this drawing tool here: Chart Drawing Tools: Type Text | Stationary Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-16 17:52:13
[2019-04-25 04:57:43] |
I see the new menu item! I just can't figure out how to use it... Is it functional for you?
[2019-04-25 08:58:57] |
We have now tested this on a Trading DOM. It is not working because it specifically has been blocked in this case but we will remove that restriction in the next release.
[2019-05-15 16:35:37] |
I've been using this feature very successfully, thank you for adding it! So much faster than the alternatives before. I've noticed it doesn't honor Chart Settings->Advanced Settings->Adjust Tool Values to Tick Size; is that easy to enable? Thanks again! edit: Once I add any study, it then does honor adjust tool values by tick size... even if I later remove the study... Date Time Of Last Edit: 2019-05-15 16:51:45
[2019-05-16 03:28:37] |
This is now resolved in 1919.
