Date/Time: Sun, 19 May 2024 23:33:08 +0000
Problems when I try to open a chartbook
View Count: 856
[2019-02-21 15:26:34] |
User145885 - Posts: 15 |
Good morning. I already installed the new version.Every time I try to upload a chartbook sierra application close it when I try to upload a chart it says something like YM or ES not authorize. I can not copy the message because it close the platform. Thanks in advance the following message occurs before I try to upload any chart. TD Ameritrade | Streamer request #1 initiated. | 2019-02-21 10:14:25 HTTP connection ID:1 to streamer-ext-bin-tx.tdameritrade.com:80 for request ID:1 (1) | Creating socket. | 2019-02-21 10:14:25 HTTP connection ID:1 to streamer-ext-bin-tx.tdameritrade.com:80 for request ID:1 (1) | Connecting to IP: 198.200.171.138. | 2019-02-21 10:14:25 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-1 | 2019-02-21 10:14:25 HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (2) | Creating socket. Using TLS 1.2. | 2019-02-21 10:14:29 HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (2) | Connecting to IP: 198.200.171.201. | 2019-02-21 10:14:29 HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (3) | Creating socket. Using TLS 1.2. | 2019-02-21 10:14:29 HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (3) | Connecting to IP: 198.200.171.201. | 2019-02-21 10:14:29 HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (4) | Creating socket. Using TLS 1.2. | 2019-02-21 10:14:29 HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (4) | Connecting to IP: 198.200.171.201. | 2019-02-21 10:14:29 HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (4) | Shutdown started. Waiting for graceful close. | 2019-02-21 10:14:29 HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (3) | Shutdown started. Waiting for graceful close. | 2019-02-21 10:14:29 HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (2) | Shutdown started. Waiting for graceful close. | 2019-02-21 10:14:29 HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (4) | Socket gracefully closed by remote side. | 2019-02-21 10:14:29 HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (4) | Closed. | 2019-02-21 10:14:29 HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (3) | Socket gracefully closed by remote side. | 2019-02-21 10:14:29 HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (3) | Closed. | 2019-02-21 10:14:29 HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (2) | Socket gracefully closed by remote side. | 2019-02-21 10:14:29 HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (2) | Closed. | 2019-02-21 10:14:29 Installer version: 7 | 2019-02-21 10:13:37 Not using HTTP proxy server settings. | 2019-02-21 10:13:40 HTTP Request: https://www.sierrachart.com/API.php?Service=GetCurrentVersionNumber | 2019-02-21 10:13:40 HTTPS www.sierrachart.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-02-21 10:13:40 HTTPS www.sierrachart.com:443 (1) | Connecting to IP: 46.4.97.203. | 2019-02-21 10:13:40 HTTP Request: https://www.sierrachart.com/downloads/1875/FilesToDownload.txt | 2019-02-21 10:13:41 Not overwriting file since it exists: 2TargetsWithBEStop.twconfig | 2019-02-21 10:13:42 Not overwriting file since it exists: 2TargetsWithCommonStop.twconfig | 2019-02-21 10:13:42 Not overwriting file since it exists: ChartbookExample.cht | 2019-02-21 10:13:42 Not overwriting file since it exists: Clean Chart.stdycollct | 2019-02-21 10:13:42 Not overwriting file since it exists: EURUSD.dly | 2019-02-21 10:13:42 Not overwriting file since it exists: SimpleBracket.twconfig | 2019-02-21 10:13:42 HTTP Request: https://www.sierrachart.com/downloads/Common1869/FilesToDownload.txt | 2019-02-21 10:13:44 Starting request of files to install. | 2019-02-21 10:13:47 HTTP request: https://www.sierrachart.com/downloads/1875/ACS_Source/SCStudyFunctions.cpp | 2019-02-21 10:13:47 HTTP request: https://www.sierrachart.com/downloads/1875/ACS_Source/scstructures.h | 2019-02-21 10:13:47 HTTP request: https://www.sierrachart.com/downloads/1875/ACS_Source/sierrachart.h | 2019-02-21 10:13:47 HTTP request: https://www.sierrachart.com/downloads/1875/DTC/DTCProtocol.cpp | 2019-02-21 10:13:47 HTTP request: https://www.sierrachart.com/downloads/1875/DTC/DTCProtocol.h | 2019-02-21 10:13:47 HTTP request: https://www.sierrachart.com/downloads/1875/DTC/DTCProtocol.proto | 2019-02-21 10:13:47 HTTP request: https://www.sierrachart.com/downloads/1875/SierraChart.exe | 2019-02-21 10:13:47 HTTP request: https://www.sierrachart.com/downloads/1875/SierraChartStudies.dll | 2019-02-21 10:13:47 HTTP request: https://www.sierrachart.com/downloads/1875/SierraChartStudies_64.dll | 2019-02-21 10:13:47 HTTP request: https://www.sierrachart.com/downloads/1875/SierraChart_64.exe | 2019-02-21 10:13:47 Received file: SCStudyFunctions.cpp | 2019-02-21 10:13:47 Received file: scstructures.h | 2019-02-21 10:13:47 Received file: sierrachart.h | 2019-02-21 10:13:47 Received file: DTCProtocol.cpp | 2019-02-21 10:13:47 Received file: DTCProtocol.h | 2019-02-21 10:13:47 Received file: DTCProtocol.proto | 2019-02-21 10:13:47 Received file: SierraChart.exe | 2019-02-21 10:13:52 Received file: SierraChartStudies.dll | 2019-02-21 10:13:52 Received file: SierraChartStudies_64.dll | 2019-02-21 10:13:52 Received file: SierraChart_64.exe | 2019-02-21 10:13:57 Starting move of SCStudyFunctions.cpp | 2019-02-21 10:13:57 Successfully moved C:\SierraChart\DownloadedInstallationFiles\ACS_Source\SCStudyFunctions.cpp file to the folder C:\SierraChart\ACS_Source\ | 2019-02-21 10:13:57 Starting move of scstructures.h | 2019-02-21 10:13:57 Successfully moved C:\SierraChart\DownloadedInstallationFiles\ACS_Source\scstructures.h file to the folder C:\SierraChart\ACS_Source\ | 2019-02-21 10:13:57 Starting move of sierrachart.h | 2019-02-21 10:13:57 Successfully moved C:\SierraChart\DownloadedInstallationFiles\ACS_Source\sierrachart.h file to the folder C:\SierraChart\ACS_Source\ | 2019-02-21 10:13:57 Starting move of DTCProtocol.cpp | 2019-02-21 10:13:57 Successfully moved C:\SierraChart\DownloadedInstallationFiles\DTC\DTCProtocol.cpp file to the folder C:\SierraChart\DTC\ | 2019-02-21 10:13:57 Starting move of DTCProtocol.h | 2019-02-21 10:13:57 Successfully moved C:\SierraChart\DownloadedInstallationFiles\DTC\DTCProtocol.h file to the folder C:\SierraChart\DTC\ | 2019-02-21 10:13:57 Starting move of DTCProtocol.proto | 2019-02-21 10:13:57 Successfully moved C:\SierraChart\DownloadedInstallationFiles\DTC\DTCProtocol.proto file to the folder C:\SierraChart\DTC\ | 2019-02-21 10:13:57 Starting move of SierraChart.exe | 2019-02-21 10:13:57 Successfully moved C:\SierraChart\DownloadedInstallationFiles\SierraChart.exe file to the folder C:\SierraChart\ | 2019-02-21 10:13:57 Starting move of SierraChartStudies.dll | 2019-02-21 10:13:57 Successfully moved C:\SierraChart\DownloadedInstallationFiles\SierraChartStudies.dll file to the folder C:\SierraChart\ | 2019-02-21 10:13:57 Starting move of SierraChartStudies_64.dll | 2019-02-21 10:13:57 Successfully moved C:\SierraChart\DownloadedInstallationFiles\SierraChartStudies_64.dll file to the folder C:\SierraChart\ | 2019-02-21 10:13:57 Starting move of SierraChart_64.exe | 2019-02-21 10:13:57 Successfully moved C:\SierraChart\DownloadedInstallationFiles\SierraChart_64.exe file to the folder C:\SierraChart\ | 2019-02-21 10:13:57 Date Time Of Last Edit: 2019-02-21 15:36:47
[2019-02-21 18:54:39] |
So you are getting an abnormal shutdown of Sierra Chart when opening a Chartbook? Run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode See if that resolves the problem. We will focus on this problem first. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-21 18:55:02
[2019-02-26 15:08:01] |
Thanks it allow me to open charts without a problem. But does not allow me to use any custom study dll.
[2019-02-26 17:44:32] |
You will need to contact the developer about this issue. Refer to help topic 17: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface when I try to upload a chart it says something like YM or ES not authorize. In regards to this provide the Message Log if you are still having a problem:https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-26 17:47:28
