Date/Time: Wed, 08 May 2024 19:32:50 +0000
SC Data Feed - no real-time
View Count: 1142
[2019-02-13 16:13:06] |
User12089 - Posts: 350 |
I/ my SC account am subscribed and enabled for 3 separate instances of SC and 3 separate instances of the SC data feed When one of my SC instances is connected directly and only to the SC data feed, I do not get Real-time Data from SC When the SC instance is connected to Interactive Brokers with support for SC data feeds enabled, I do get real time data from SC ie I see the [m] too The above also means that have connected SC "at least once per month to a funded IB account" as per the instructions from SC. However as soon as I connect the SC instance directly and only to the SC data feed, it stops receiving real-time data from SC. Why is that and how do I overcome it? this is an effect observed when there is a second SC instance running on a separate machine and connected to IB with support for SC data enabled. So to recap that would mean that there are 2 SC instances trying to connected to SC data at the same time - and that should be possible and not interfere, since my SC account is enabled / subscribed for 3 SC instances and 3 SC data feeds |
[2019-02-13 16:13:51] |
Sierra Chart - Max - Posts: 5608 |
1. You would need to connect each of your instances to IB at least once a month. 2. If you are connecting directly to "SC Data - All Services", make sure that you are not using IB specific symbols. User's response: 1. You would need to connect each of your instances to IB at least once a month. already done - and as already clearly explained in the initial ticket submission .... 2. If you are connecting directly to "SC Data - All Services", make sure that you are not using IB specific symbols. I am a 5 year SC client, mate. I do know the differences between symbols from different data feeds .... basically I have a strong suspicion that your Infrastructure for multiple SC instances and multiple data feed connections does NOT work for the case when SC is supposed to connect directly to SC datafeed (and mind you, as explained below - only 1 min earlier I connected it to IB ... so that's not the problem) Go check in the logs of your market data infrastructure why it is not sending me real-time data when a SECOND SC is connected directly to it - I am paid for 3 SC instances and 3 data feeds .... Sierra Chart Support |
[2019-02-13 16:17:23] |
and the new feature for getting Option Chains from IB in SC doesn't work properly either - but that's obviously a separate issue - we can tackle it once the one here has been resolved
Date Time Of Last Edit: 2019-02-13 16:22:26
[2019-02-13 16:21:38] |
Tell us one of the symbols that is not receiving real-time data and just one symbol only. Provide a copy of the Message Log from that instance by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-13 16:21:53
[2019-02-13 16:23:06] |
yep sure - lets start with the usual suspect - ES
[2019-02-13 16:29:50] |
Provide a copy of the Message Log from that instance by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-13 16:50:39] |
I have repeated every step and this time managed to get a Real-Time SC data feed for my second SC instance - most likely there is some sort of "lead time" after the initial IB connection for the direct SC feed to get validated and allowed - this issue is now working for me On a separate note - I think there are issues with the new SC feature for getting IB Options Chains in SC - see the last record below - this is the error message generated when I try to get the option chains for the CURRENT (March) ES contract and nothing comes back. However if it try the next expiration then I do get a list of Options. But then the option symbols don't seem to be able to go in SC chart - I will send you the respective error messages - lets resolve first this one Software version: 1852 64-bit | 2019-02-13 16:43:19 Usage end date: 2019-05-07 | 2019-02-13 16:43:19 Enabled for: Advanced Features. | 2019-02-13 16:43:19 Enabled for: Advanced Features 2. | 2019-02-13 16:43:19 Enabled for: Sierra Chart Historical Data Service. | 2019-02-13 16:43:19 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-02-13 16:43:19 Enabled for: INDEXES_DATA_BARCHART | 2019-02-13 16:43:19 Enabled for: CME (Trading Account Required) | 2019-02-13 16:43:19 Enabled for: CBOT (Trading Account Required) | 2019-02-13 16:43:19 Enabled for: COMEX (Trading Account Required) | 2019-02-13 16:43:19 Enabled for: NYMEX (Trading Account Required) | 2019-02-13 16:43:19 Enabled for: ICE USA | 2019-02-13 16:43:19 Enabled for: Eurex with Market Depth | 2019-02-13 16:43:19 Received 3 data feed usernames. | 2019-02-13 16:43:19 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-02-13 16:43:19 Current selected Data/Trading service: Interactive Brokers | 2019-02-13 16:43:19 Chart Update Interval: 500 | 2019-02-13 16:43:19 Time Zone: +00:00:00 (UTC+00) | 2019-02-13 16:43:19 2019-02-13 16:43:18 Local computer time | 2019-02-13 16:43:19 2019-02-13 16:43:18 Local computer time in UTC | 2019-02-13 16:43:19 2019-02-13 16:43:18 Local computer time in SC Time Zone | 2019-02-13 16:43:19 2019-02-13 15:33:49 Server time in UTC | 2019-02-13 16:43:19 Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-02-13 16:43:19 Program path: C:\SierraChart\ | 2019-02-13 16:43:19 Data Files path: C:\SierraChart\Data\ | 2019-02-13 16:43:19 OS Version Number: 10.0 | 2019-02-13 16:43:19 Locale Setting: C | 2019-02-13 16:43:19 DLLs: BreachBot.dll, BreachBot_64.dll, chartdir60.dll, chartdir60_64.dll, sceetobots.dll, sceetobots_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-02-13 16:43:19 Message from IB: Error validating request:-'cl' : cause - Invalid security type - . IB Error Code: 321. Request ID: 1000002. | 2019-02-13 16:43:42 |
[2019-02-13 16:57:05] |
- most likely there is some sort of "lead time" after the initial IB connection for the direct SC feed to get validated and allowed - No there is not. The instance of Sierra Chart connected to a live futures trading account, gets instantly authorized to receive CME data.Message from IB: Error validating request:-'cl' : cause - Invalid security type - . IB Error Code: 321. Request ID: 1000002. | 2019-02-13 16:43:42 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-13 16:57:28
[2019-02-13 18:00:19] |
and here is the mess when you select an Option from the Option Chain (which is ONLY returned for the NEXT expiration date of the underlying futures contract - ES in this case - basically the feature for IB Option Chains doesn't work) Interactive Brokers | Starting real-time market data updates for: ES-FOP-20190322-C-GLOBEX-50--EW4. ID: 1 | 2019-02-13 17:55:27 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FOP, Expiration: 20190322, Exchange: 50, Primary Exchange: , Currency: EW4, Multiplier: , CallPut: GLOBEX, Strike: C, LocalSymbol: , TradingClass: | 2019-02-13 17:55:27 Interactive Brokers | Requesting security definition data for: ES-FOP-20190322-C-GLOBEX-50--EW4. ID: 1 | 2019-02-13 17:55:27 Interactive Brokers | Using primary service for historical data for ES-FOP-20190322-C-GLOBEX-50--EW4 | 2019-02-13 17:55:27 Intraday data recording state for symbol ES-FOP-20190322-C-GLOBEX-50--EW4 is set to download 'Pending'. | 2019-02-13 17:55:27 Delaying start of download for ES-FOP-20190322-C-GLOBEX-50--EW4 | 2019-02-13 17:55:27 Socket (1) | Socket gracefully closed by remote side. | 2019-02-13 17:55:27 Message from IB: Error reading request:Message id 1. Unable to parse data. java.lang.NumberFormatException: For input string: "C". IB Error Code: 320. Request ID: 1. Symbol: ES-FOP-20190322-C-GLOBEX-50--EW4. | 2019-02-13 17:55:27 Connection to the external service has been lost. | 2019-02-13 17:55:27 Socket (1) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2019-02-13 17:55:27 * Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-13 17:55:27 Socket (1) | Closed. | 2019-02-13 17:55:27 Interactive Brokers | Disconnected. | 2019-02-13 17:55:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-13 17:55:27 |
[2019-02-14 09:05:09] |
For some reason we did not include the strike price. Surprising this has not been noticed until now. This is resolved and we will have new release out later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-14 11:39:07] |
ok but I have not yet heard anything from you about why SC doesn't pull the Option Chain for the current futures contract e.g. the ES - I have tested that with both the latest IB TWS and the latest SC and no brother it aint working it only pulls the Option Chain for e.g. the next expiration ie ES June but not for the current expiration which is ES Mar Date Time Of Last Edit: 2019-02-14 11:40:07
[2019-02-14 18:50:56] |
It works consistently reliable for us. Refer to the attachment. So if you are not getting the options list, this is going to be an issue on the TWS side.
ES March options.png / V - Attached On 2019-02-14 18:50:23 UTC - Size: 25.11 KB - 339 views |
[2019-02-14 18:56:34] |
Message from IB: Error validating request:-'cl' : cause - Invalid security type - . IB Error Code: 321. Request ID: 1000002. | 2019-02-13 16:43:42 I happen to be a software engineer - the above translated in "human speak" says that IB TWS is not happy with the "Request ID: 1000002" sent by ... you guess it from 3 times who it was sent by Date Time Of Last Edit: 2019-02-14 18:57:05
[2019-02-16 03:42:19] |
And what is the exact symbol that you selected when getting the options?
[2019-02-19 16:27:09] |
ES March - not working but for ES June working .... Date Time Of Last Edit: 2019-02-19 16:27:49
[2019-02-19 18:52:38] |
We do not see how we can help with this. That is going to be an Interactive Brokers problem. We also do not see any problem getting the options for ES March 2019.
