Date/Time: Sat, 27 Apr 2024 12:23:41 +0000
Anyone else having constant (Not responding) since moving to Sierra data?
View Count: 725
[2019-02-13 15:22:01] |
Adam - Posts: 141 |
Since moving to Sierra real time data (CME) all i'm getting is not responding, its driving me nuts. i have restarted SC 20 times. Was fine when using CTS See image it whenever it goes back and updates intraday data |
2019-02-13_15h18_11.png / V - Attached On 2019-02-13 15:20:26 UTC - Size: 14.35 KB - 215 views 2019-02-13_15h19_36.png / V - Attached On 2019-02-13 15:20:38 UTC - Size: 4.88 KB - 196 views Attachment Deleted. |
[2019-02-13 16:17:55] |
No one else is having an issue like this. It is not related to the data feed. This is not possible. It is some other issue. Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often We want you to start with a new Chartbook, if the current one is using a lot of CPU usage. And then you can gradually figure out what the problem is with the existing one. You could work on it in a sub instance of Sierra Chart: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-13 16:18:21
[2019-02-14 22:39:24] |
If you are running version 1870 through 1874, this issue is now resolved assuming it was related to the deadlock condition affecting those versions. We do apologize for that.
