Date/Time: Mon, 13 May 2024 10:05:43 +0000
AMP Futures Demo
View Count: 1328
[2019-01-15 01:41:42] |
User681055 - Posts: 3 |
I would like to activate CQGWEBAPI for my sierra charts trial demo with AMP Futures.
[2019-01-15 03:17:49] |
This is now done.
[2019-01-15 16:02:57] |
Thank you. However, this price does not appear to be in real time? Is there a setting on my end that needs to be activated?
[2019-01-15 19:26:35] |
No. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-16 12:49:16] |
I followed the instructions and still no movement in price. http://www.sierrachart.com/image.php?Image=1547642909702.png |
SC_0743AM.jpg / V - Attached On 2019-01-16 12:45:32 UTC - Size: 235.07 KB - 329 views |
[2019-01-16 19:07:45] |
Follow the instructions here to use CQG: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-16 19:07:55
