Date/Time: Thu, 09 May 2024 18:11:43 +0000
Matching EURUSD with 6E
View Count: 1350
[2019-01-10 07:33:22] |
trad - Posts: 23 |
Ofcourse price of EURUSD and 6E (front month) don't match. EURUSD (FXCM EURUSD feed is at 1.1550 and 6EH19 is at 1.1613 at the moment) I was just wondering if there is any simple method to automatically update the axis atleast (and prices too if not too hard) of 6E to that of EURUSD. If this is not possible automatically, can this be done manually and recalculate periodically? Date Time Of Last Edit: 2019-01-10 07:34:31
[2019-01-10 18:51:32] |
You could adjust the Price Multipliers in the chart to see if you can get them to match: Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) However, this really would be imperfect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-10 19:44:42] |
You can have the time scales synced by using the Linking option for Scroll Position. Refer to the following: Chart Settings: Chart Linking (Chart >> Chart Settings >> Linking menu) Also, if you want to have the Crosshairs showing the same bar information on the two charts, you would want to enable Tools >> Global Cursor. Refer to the following: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) The Real-Time Price Multiplier found on Chart >> Chart Settings >> Advanced Settings 2 will allow you to modify the prices of one symbol by a specific value (i.e. you would need to occasionally update it manually). Refer to the following: Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) It is possible to create an ACSIL study that could adjust the Real-Time Price Multiplier. Refer to the following for the basic information on creating an ACSIL study: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-13 11:59:10] |
trad - Posts: 23 |
Thank you guys. I am trying to use the multiplier feature and am experiencing a strange behavior. Immediately after I apply any multiple, chart reloads with the new values and then immediately reloads with the original values ... Basically new settings gets reset immediately after first reload. I am removed all studies, and this is still happening. What gives? |
[2019-01-13 17:50:04] |
The explanation for this is because the chart is being referenced by another chart: Unable to Change the Bar Time Period for Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-29 13:28:28] |
trad - Posts: 23 |
Hi Guys, I dont see any RefBy in the titlebar of the chart settings, yet when I apply multiplier, chart snaps back to the original values. This is even after I have copied the chart to a brand new chartbook and deleted all studies. Am I missing anything? Date Time Of Last Edit: 2019-01-29 21:25:10
Capture.PNG / V - Attached On 2019-01-29 13:28:09 UTC - Size: 41.41 KB - 270 views support.Cht - Attached On 2019-01-29 13:33:13 UTC - Size: 24.63 KB - 248 views |
[2019-01-30 19:17:28] |
First we want you to log into this Support Board with the Sierra Chart account you are currently using. You can do that with Help >> Support Board. You need to disable this option for the chart: Chart Settings: Auto Set from Data Feed (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-30 19:17:51
