Date/Time: Sun, 19 May 2024 03:16:12 +0000
Numbers bar calculated values - Large Number Display Formatting?
View Count: 2062
[2018-12-09 19:57:17] |
DramaticFanatic - Posts: 12 |
Is there a way to have the 'large number display formatting' option on Numbers Bars Calculated Values like there is for Numbers Bars and VbP volume profile study? I currently have XBTUSD Numbers bar displaying the correct values in abbreviation eg. 1.2m/3m/500k/200k contracts but that abbreviation doesn't apply to Numbers Bars calculated values because there is no "large number display formatting" option like in the above mentioned studies so it will display the full values eg. 1200000/3000000/etc... |
[2018-12-10 18:16:31] |
We will be adding this option in the future. Give us a few weeks to get to it.
[2019-02-02 04:23:39] |
Thanks! Any update on this functionality?
[2019-02-02 16:19:30] |
Sorry, we have just been busy with other updates lately. This is still on our list to get done soon, but give us a few more weeks.
[2019-03-06 22:17:59] |
Sorry for the delay on the answer. While we were working on this, we realized that the ability to use the Large Number Formatting already exists for the Numbers Bars Calculated Values. Just set the Value Format for the study to the option Large Integer with Suffix. You will find the information on how to do this here: Chart Studies: Settings and Inputs Tab >> Value Format You will find the information on how this works for the Numbers Bars Calculated Values here, although we will be updating this to make it more obvious that this option is available: Numbers Bars: Calculated Values Number Format Also note that there are some values that will not display correctly when this option is selected in the current versions. We have fixed this particular issue and it will be in the next Pre-Release (v 1882). To do this, we forced the Value Format for non-integer items like Average Bid Volume and Average Ask Volume to use the Value Format of the main graph. The downside of this is that these numbers will not use the suffix when selected as these are not Integer values. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
