Date/Time: Mon, 29 Apr 2024 10:16:11 +0000
After 1850 upgrade unable to access data from other instances of SierraChart on machine
View Count: 911
[2018-12-09 06:45:34] |
User65754 - Posts: 25 |
Hi, I upgraded my SierraChart instances: my direct subscription to Sierrachart to 1850 (64Bit) 25512M my Infinity Futures install to 1850 (32Bit) 25512M Now I am unable to use data charts from the other instance. For example previously I had subscribed to a bunch of exchanges on my direct subscription and I was able to use those charts from within my Infinity Futures install ... now they are gone. The option to select this instance or the other instance DOES NOT EVEN SHOW UP. I run both the direct subscription instance and the Infinity Futures instance as Administrator ... Please help - without accessing data from the direct subscription in my Infinity Futures instance I CANNOT TRADE. BTW it is same behavior from both sides I cannot access Infinity Futures charts in direct subscription instance either ... the option itself is not shown anymore in all cases (infinity futures instance and direct subscription instance) ... See image for explanation of option I am talking about ... |
accessingdatassue.png / V - Attached On 2018-12-09 06:44:06 UTC - Size: 129.19 KB - 284 views |
[2018-12-09 08:54:22] |
Hi, How do I access for example $INX data subscribed in SierraChart direct subscription instance in my Infinity Futures instance? ($INX chart loads correctly inside direct subscription instance .... but there is no way I can see to access this data in my Infinity Futures instance) Both instances are installed in separate folders and are on the same Win10 machine. I run them both as "administrator" (still does not work) Everything was working fine for years until the upgrade to 1850 today. Please help. |
[2018-12-09 12:09:17] |
Usermb - Posts: 126 |
Might want to look at this: Breaking Change: Remote Chart Data Files
[2018-12-09 13:51:44] |
User75096 - Posts: 48 |
HI, here the same 1847 was fine with my 2. instance now i dont get data in the 2. instance and the first instance will reconnect all the time , im using CQG , as i sais till 1847 all was fine, even reinstall 1847 will not work , i have to install a backup of my saved 1847 to get it all working again, thanks |
[2018-12-09 20:50:59] |
In response to post #1, refer to: Breaking Change: Remote Chart Data Files In response to post #2, we will put together an example for this: How do I access for example $INX data subscribed in SierraChart direct subscription instance in my Infinity Futures instance? ($INX chart loads correctly inside direct subscription instance .... but there is no way I can see to access this data in my Infinity Futures instance) It is supported and supported in a superior way but we just need to explain how to do it. Just give us another one to two days for this. HI, here the same 1847 was fine with my 2. instance now i dont get data in the 2. instance and the first instance will reconnect all the time , im using CQG , The issue you are having is not related to any particular Sierra Chart version. This is with certainty. There is some other problem and we would have to get a precise description of the issue and a Message Log to help you with this.as i sais till 1847 all was fine, even reinstall 1847 will not work , i have to install a backup of my saved 1847 to get it all working again, thanks And the fact that you went back to a prior version and still have the issue confirms what we are saying. There must be some kind of configuration problem. Or a CQG server issue. But this is hard to say because we do not even have a clear understanding of the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-09 23:04:38] |
thanks for your replay , i could fix it , the prob was in few chartbooks, thanks again
[2018-12-10 00:33:01] |
the problem was the quote board,if i wanna open a quote board i will get reconnection
[2018-12-10 02:24:59] |
I am able to setup a DTC server inside my SierraChart subscription (where I have the realtime $INX data available) as documented. BUT in my Infinity SierraChart I have no way of accessing the "DTC Sub instance" under Data/Trade Service settings (so that I can try to get the $INX data from the SierraChart subscription into the Infinity instance) as that pull down menu is grayed out (see screen capture). |
[2018-12-10 02:30:33] |
Screen shot of Infinity "Data Trade Settings" which does not allow me to configure "DTC Sub Instance"
InfinityDTC.png / V - Attached On 2018-12-10 02:30:20 UTC - Size: 92.76 KB - 323 views |
[2018-12-11 14:49:40] |
Here is the documentation for accessing data from one instance of Sierra Chart in another instance: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart which does not allow me to configure "DTC Sub Instance" This feature does not rely on this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-11 14:50:24
