Date/Time: Mon, 06 May 2024 13:15:15 +0000
Calculated numbers bars (Finish and Fininsh%) explain
View Count: 1448
[2018-12-06 21:03:23] |
MARTIN CREUSOT - Posts: 2 |
Hello Support, I wish to understand why the calculation of the Finish is not correct as in the following example. The Delta must substracted from the highest value from the min or the max delta to get the value of the finish. Do you have an explanation ? Besides, do you have done some extensive videos relative to the explanation of the use the Number Bars Calculated Values ? Thanks. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=24196 |
[2018-12-06 22:21:30] |
The calculation is definitely correct. We need a more detailed explanation of why you think there is a problem. And when posting an image of a chart, follow these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Also make sure Sierra Chart is set to a tick by tick configuration: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-06 22:22:42
[2018-12-10 15:44:04] |
Sierra Chart - Max - Posts: 5605 |
From User: i think the finish is : Delta - (Max delta our Min delata) no ? Sierra Chart Support |
[2018-12-10 19:28:57] |
You need to refer to the documentation for the formula.: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-10 19:29:41
