Date/Time: Sat, 18 May 2024 07:13:55 +0000
S&P Advance Decline line
View Count: 3057
[2018-10-29 16:10:28] |
User652173 - Posts: 4 |
Good morning. I am trading S&P mini with Sierra and CQG. When I add the advanced decline line to my chart I get an upward bar across the screen and am not able to find a way to fix it. Question - how do I correctly add the S&P Advance Decline Line to my chart? Thanks, Curt |
[2018-10-29 17:43:45] |
You need to use the Sierra Chart Market Statistics Data Feed: Sierra Chart Market Statistics The symbol you want is: NISS-NYSE. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-31 20:01:00
[2018-10-29 18:50:55] |
Hi, Thanks for your reply. I am having a difficult time finding where to enter in the symbol. I spent a fair amount of time following the instructions however I got nowhere. I enter the symbol NISS-NYSE for the S&P Advanced Decline? Where do I enter the appropriate symbol? Thanks, Curt |
[2018-10-29 19:27:15] |
You just need to open a chart for that symbol. Refer to: Getting Started, Opening Charts and Basic Trading: Open Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-29 19:27:36
[2018-10-29 20:17:26] |
Ok, got that open. How do I get that chart at the bottom of my current trading chart. I have found a way to add volume and average true range, how do I add the adv/decl? Curt |
[2018-10-29 20:51:33] |
This is explained in this particular section here: Sierra Chart Market Statistics: Overlaying a Chart on Another Chart as a Study (Overlaying a Chart on Another Chart as a Study) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-29 20:51:43
[2018-10-31 19:12:46] |
Hi, I think I got it. What is the Sierra symbol for the NYSE Tick ? Curt |
[2018-10-31 20:01:29] |
This is documented here: Sierra Chart Market Statistics: Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
