Date/Time: Mon, 20 May 2024 14:58:21 +0000
Regarding Rithmic
View Count: 1430
[2018-10-12 20:34:23] |
For an understanding of the connection parameters difference between what Rithmic says Sierra Chart should be using and what Sierra Chart is currently using, see the attached screenshot. What Sierra Chart is using is on the right side. You can see they are minor and effectively there is no difference in the domain names. Whatever the connectivity issue today was, we would think Rithmic would be able to resolve this from their side understanding the connection parameters being used. For a reason why we cannot update the settings, refer to: https://www.sierrachart.com/SupportBoard.php?PostID=149895#P149895 One thing we can potentially do is rollback the code for the Rithmic bridge program to an earlier state when there apparently was not a problem and build and release that but we are not comfortable with that with all of the code updates we have done since then. And then we would have trouble using an earlier version of Visual C++ most likely. What we tried right now is doing a release build of the Rithmic bridge and tested the execution of it. It seems to run fine but being we see unstable behavior in the debug build we are not totally sure about releasing it but we will go ahead and do that. It will be in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-13 03:22:34
2018-10-13_092927.png / V - Attached On 2018-10-13 03:22:25 UTC - Size: 62.14 KB - 362 views |
[2018-10-13 03:22:50] |
For some reason the screenshot did not get attached. It is now attached above.
[2018-10-13 03:57:46] |
So the latest revision of 1821 which we are going to release within an hour will have an updated Rithmic bridge program which is built using their latest libraries and has the latest connection details. We want to know if users experience any instability with that program. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-14 23:20:58] |
Cavalry3162 - Posts: 523 |
just so you know, i am unable to connect to the rithmic feed.. constantly getting logon error.. it works fine with r|trader thanks, Andreas |
[2018-10-14 23:29:39] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-14 23:52:55] |
Also it really is very clear Rithmic can solve this issue from their side. And they should. And we do not know whether this new bridge program is going to be stable or not. It would have been very irresponsible for us in the past to have released it but we are now and we do not even know what the consequence of it is going to be. It could be fine but in our judgment, it should not be trusted. But to what extent it is going to cause a problem we do not know. For example we would never release our main program Sierra Chart with such a problem. We would determine the problem and resolve it. But this situation is unresolvable by us because we do not control the source code and because the whole concept of using an API component is ridiculous to begin with. We explain this in help topic 76: Sierra Chart Does not Support External Service API Components And when our users wonder why periodically we put Rithmic down it is because of this reason. Look at the trouble you are facing with Rithmic connectivity. We are only being proven right here. And for anyone to put blame or responsibility on us is completely out of bounds. So at this point, we recommend strongly for Rithmic to take the necessary steps on their side to support the connection details we are currently using. There should be no trouble with this. And then they need to get the new websocket and Google protocol buffer API out which bypasses this client-side component. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-15 00:16:54
[2018-10-15 06:35:57] |
i am on 1821 (latest available pre release to me...) Login call failed. Error code: API_BAD_INPUT Reading Internal Order ID file. | 2018-10-15 02:32:56
Reading Trade Orders file. | 2018-10-15 02:32:56 Reading Trade Positions file. | 2018-10-15 02:32:56 Account Balance file. | 2018-10-15 02:32:56 Listening on UDP port 22903. | 2018-10-15 02:32:56 Software version: 1821 64-bit | 2018-10-15 02:32:56 Usage end date: 2019-10-12 | 2018-10-15 02:32:56 Enabled for: Advanced Features. | 2018-10-15 02:32:56 Enabled for: Advanced Features 2. | 2018-10-15 02:32:56 Enabled for: Sierra Chart Historical Data Service. | 2018-10-15 02:32:56 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-10-15 02:32:56 Enabled for: INDEXES_DATA_BARCHART | 2018-10-15 02:32:56 Enabled for: CME (Trading Account Required) | 2018-10-15 02:32:56 Enabled for: CBOT (Trading Account Required) | 2018-10-15 02:32:56 Enabled for: COMEX (Trading Account Required) | 2018-10-15 02:32:56 Enabled for: NYMEX (Trading Account Required) | 2018-10-15 02:32:56 Enabled for: Eurex with Market Depth | 2018-10-15 02:32:56 Received 1 data feed usernames. | 2018-10-15 02:32:56 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-10-15 02:32:56 Current selected Data/Trading service: Rithmic Trading | 2018-10-15 02:32:56 Chart Update Interval: 600 | 2018-10-15 02:32:56 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-10-15 02:32:56 2018-10-15 02:32:56 Local computer time | 2018-10-15 02:32:56 2018-10-15 06:32:56 Local computer time in UTC | 2018-10-15 02:32:56 2018-10-15 02:32:56 Local computer time in SC Time Zone | 2018-10-15 02:32:56 2018-10-15 06:32:55 Server time in UTC | 2018-10-15 02:32:56 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-10-15 02:32:56 Program path: C:\SierraChart\ | 2018-10-15 02:32:56 Data Files path: C:\SierraChart\Data\ | 2018-10-15 02:32:56 OS Version Number: 10.0 | 2018-10-15 02:32:56 Locale Setting: C | 2018-10-15 02:32:56 Created the DTC Protocol server. | 2018-10-15 02:32:56 DTC Protocol Server listening on port 12000. | 2018-10-15 02:32:56 Created the DTC Protocol historical data server. | 2018-10-15 02:32:56 HD Server Manager | Listening on port 11999 | 2018-10-15 02:32:56 Checking for new symbol settings for service code rithmic.trading | 2018-10-15 02:32:56 HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-10-15 02:32:56 HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-10-15 02:32:56 Received 5 login tokens. | 2018-10-15 02:32:57 Symbol settings are up-to-date for rithmic.trading | 2018-10-15 02:32:57 HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-10-15 02:32:58 HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-10-15 02:32:58 Files to Open on Start up | Opening file: Crude Oil.Cht | 2018-10-15 02:33:00 CLX8-NYMEX [CBV] 1000 Volume #1 | Reloading chart. | 2018-10-15 02:33:00 CLX8-NYMEX [CBV] 1000 Volume #1 | Performing historical Daily data download for symbol CLX18 starting at last date in file. | 2018-10-15 02:33:00 CLX8-NYMEX [CBV] 1000 Volume #1 | Waiting for historical downloads to complete with the IDs: 1, | 2018-10-15 02:33:00 CLX8-NYMEX [CBV] #2 | Reloading chart. | 2018-10-15 02:33:00 CLX8-NYMEX [CBV] #2 | Waiting for historical downloads to complete with the IDs: 1, | 2018-10-15 02:33:00 CLX8-NYMEX [CBV] #3 | Reloading chart. | 2018-10-15 02:33:00 CLX8-NYMEX [CBV] #3 | Waiting for historical downloads to complete with the IDs: 1, | 2018-10-15 02:33:00 CLX8-NYMEX [CB] 5 Min #4 | Reloading chart. | 2018-10-15 02:33:00 CLX8-NYMEX [CB] 5 Min #4 | Waiting for historical downloads to complete with the IDs: 1, | 2018-10-15 02:33:00 CLX8-NYMEX [CB] #5 | Reloading chart. | 2018-10-15 02:33:00 CLX8-NYMEX [CB] #5 | Waiting for historical downloads to complete with the IDs: 1, | 2018-10-15 02:33:00 CLX8-NYMEX [CBV] #6 | Reloading chart. | 2018-10-15 02:33:00 CLX8-NYMEX [CBV] #6 | Waiting for historical downloads to complete with the IDs: 1, | 2018-10-15 02:33:00 CLX8-NYMEX [CBV] Weekly #7 | Reloading chart. | 2018-10-15 02:33:00 HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-10-15 02:33:01 HTTPS login.sierrachart.com:443 (1) | Received socket Close event. | 2018-10-15 02:33:01 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-10-15 02:33:02 HTTPS www.sierrachart.com:443 (2) | Received socket Close event. | 2018-10-15 02:33:02 HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-10-15 02:33:02 HTTPS www.sierrachart.com:443 (4) | Received socket Close event. | 2018-10-15 02:33:02 CLX8-NYMEX [CBV] Monthly #8 | Reloading chart. | 2018-10-15 02:33:03 HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-10-15 02:33:04 HTTPS www.sierrachart.com:443 (5) | Received socket Close event. | 2018-10-15 02:33:04 CLX8-NYMEX [CBV] 7500 Volume #9 | Reloading chart. | 2018-10-15 02:33:06 CLX8-NYMEX [CBV] 7500 Volume #9 | Waiting for historical downloads to complete with the IDs: 1, | 2018-10-15 02:33:07 CLX8-NYMEX [CBV] 30 Min #10 | Reloading chart. | 2018-10-15 02:33:07 CLX8-NYMEX [CBV] 30 Min #10 | Waiting for historical downloads to complete with the IDs: 1, | 2018-10-15 02:33:07 CLX8-NYMEX [CBV] Daily #11 | Reloading chart. | 2018-10-15 02:33:07 CLX8-NYMEX [CBV] Rev. 16t #12 | Reloading chart. | 2018-10-15 02:33:08 CLX8-NYMEX [CBV] Rev. 16t #12 | Waiting for historical downloads to complete with the IDs: 1, | 2018-10-15 02:33:08 USDTRY Daily #14 | Reloading chart. | 2018-10-15 02:33:08 RBX8-NYMEX [CBV] Daily #13 | Reloading chart. | 2018-10-15 02:33:08 HD Request # 2 | Downloading Historical Daily chart data for CLX18. Starting date: 2018-10-11. Service: rithmic.trading | 2018-10-15 02:33:08 HD Request # 2 | Using user Barchart Historical data account. | 2018-10-15 02:33:08 HD Request # 2 | Requesting historical Daily data for CLX18 starting at 2018-10-10 | 2018-10-15 02:33:08 HTTPS historicaldata.sierrachart.com:443 (6) | Creating socket. Using TLS 1.2. | 2018-10-15 02:33:08 HTTPS historicaldata.sierrachart.com:443 (6) | Connecting to IP: 88.99.0.216. | 2018-10-15 02:33:08 HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2018-10-15 02:33:08 HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-15 02:33:08 HTTPS login.sierrachart.com:443 (1) | Closed. | 2018-10-15 02:33:08 HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2018-10-15 02:33:08 HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-15 02:33:08 HTTPS www.sierrachart.com:443 (2) | Closed. | 2018-10-15 02:33:08 HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2018-10-15 02:33:08 HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-15 02:33:08 HTTPS www.sierrachart.com:443 (4) | Closed. | 2018-10-15 02:33:08 HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2018-10-15 02:33:08 HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-15 02:33:08 HTTPS www.sierrachart.com:443 (5) | Closed. | 2018-10-15 02:33:08 Mapping CLX8-NYMEX to CLX18. Service code: nymex | 2018-10-15 02:33:08 Using Bid/Ask average for last trade price for USDTRY | 2018-10-15 02:33:09 HD Request # 3 | Downloading Historical Daily chart data for USDTRY. Starting date: 2018-10-12. Service: fxcm | 2018-10-15 02:33:09 HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2018-10-15 02:33:09 Socket (1) | Creating socket. | 2018-10-15 02:33:09 Socket (1) | Connecting to IP: 192.81.56.146. | 2018-10-15 02:33:09 Mapping RBX8-NYMEX to RBX18. Service code: nymex | 2018-10-15 02:33:09 HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-10-15 02:33:09 HD Request # 3 | Sending historical data logon request message. | 2018-10-15 02:33:09 HD Request # 3 | Requesting historical Daily data starting at 2018-10-12. | 2018-10-15 02:33:09 HD Request # 3 | Decompressing data. | 2018-10-15 02:33:09 HD Request # 3 | Receiving historical Daily data for USDTRY starting at 2018-10-12 | 2018-10-15 02:33:09 HD Request # 3 | Writing historical Daily data to the file USDTRY.dly | 2018-10-15 02:33:09 Socket (1) | Signaling to core to close socket | 2018-10-15 02:33:09 Socket (1) | Shutdown started. Waiting for graceful close. | 2018-10-15 02:33:09 Historical data download thread signaled to stop. | 2018-10-15 02:33:09 HD Request # 3 | Received 2 records from 2018-10-12 00:00:00 to 2018-10-15 00:00:00 (4.0 days) and wrote 2 records for USDTRY | 2018-10-15 02:33:09 HD Request # 3 | Completion time: 1s | 2018-10-15 02:33:09 HD Request # 3 | Daily data download complete for USDTRY. Unique request ID: 3 | 2018-10-15 02:33:09 Removed historical data download ID 3 | 2018-10-15 02:33:09 Socket (1) | Socket gracefully closed by remote side. | 2018-10-15 02:33:09 Socket (1) | Closed. | 2018-10-15 02:33:09 USDTRY [M] Daily #14 | Reloading chart. | 2018-10-15 02:33:09 HD Request # 2 | Receiving historical Daily data for CLX18 starting at 2018-10-11 | 2018-10-15 02:33:09 HD Request # 2 | Writing historical Daily data to the file CLX18.dly | 2018-10-15 02:33:09 HD Request # 2 | Received 4 records from 2018-10-11 00:00:00 to 2018-10-15 00:00:00 (5.0 days) and wrote 3 records for CLX18 | 2018-10-15 02:33:09 HD Request # 2 | Completion time: 0s | 2018-10-15 02:33:09 HD Request # 2 | Daily data download complete for CLX18. Unique request ID: 1 | 2018-10-15 02:33:09 Removed historical data download ID 1 | 2018-10-15 02:33:09 HD Request # 4 | Downloading Historical Daily chart data for CLX8-NYMEX. Starting date: 2018-10-12. Service: rithmic.trading | 2018-10-15 02:33:09 HD Request # 4 | Using user Barchart Historical data account. | 2018-10-15 02:33:09 HD Request # 4 | Requesting historical Daily data for CLX18 starting at 2018-10-11 | 2018-10-15 02:33:09 CLX8-NYMEX [CBV] Rev. 16t #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2018-10-15 02:33:09 CLX8-NYMEX [CBV] Rev. 16t #12 | Reloading chart. | 2018-10-15 02:33:09 CLX8-NYMEX [CBV] 30 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] 30 Min #10 | Reloading chart. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] 1000 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] 1000 Volume #1 | Reloading chart. | 2018-10-15 02:33:10 CLX8-NYMEX [CB] #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2018-10-15 02:33:10 CLX8-NYMEX [CB] #5 | Reloading chart. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] 7500 Volume #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] 7500 Volume #9 | Reloading chart. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] 30 Min #10 | Reloading chart. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] Rev. 16t #12 | Reloading chart. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] #6 | Reloading chart. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] 1000 Volume #1 | Reloading chart. | 2018-10-15 02:33:10 CLX8-NYMEX [CB] #5 | Reloading chart. | 2018-10-15 02:33:10 Intraday data recording state for symbol CLX8-NYMEX is set to download 'Pending'. | 2018-10-15 02:33:10 HD Request # 5 | Downloading Intraday chart data for CLX8-NYMEX to the file CLX8-NYMEX.scid. Service: nymex | 2018-10-15 02:33:10 HD Request # 5 | Download start date-time: 2018-10-14 19:08:19.000 | 2018-10-15 02:33:10 HD Request # 5 | Using server: ds7.sierracharts.com port 10150 | 2018-10-15 02:33:10 Socket (1) | Creating socket. | 2018-10-15 02:33:10 Socket (1) | Connecting to IP: 8.18.161.133. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] #2 | Reloading chart. | 2018-10-15 02:33:10 HD Request # 4 | Receiving historical Daily data for CLX8-NYMEX starting at 2018-10-12 | 2018-10-15 02:33:10 HD Request # 4 | Writing historical Daily data to the file CLX8-NYMEX.dly | 2018-10-15 02:33:10 HD Request # 5 | Setting DTC encoding to Binary VLS | 2018-10-15 02:33:10 HD Request # 5 | Sending historical data logon request message. | 2018-10-15 02:33:10 HD Request # 4 | Received 3 records from 2018-10-12 00:00:00 to 2018-10-15 00:00:00 (4.0 days) and wrote 2 records for CLX8-NYMEX | 2018-10-15 02:33:10 HD Request # 4 | Completion time: 0s | 2018-10-15 02:33:10 HD Request # 4 | Daily data download complete for CLX8-NYMEX. Unique request ID: 2 | 2018-10-15 02:33:10 Removed historical data download ID 2 | 2018-10-15 02:33:10 HD Request # 6 | Downloading Historical Daily chart data for RBX8-NYMEX. Starting date: 2018-10-12. Service: rithmic.trading | 2018-10-15 02:33:10 HD Request # 6 | Using user Barchart Historical data account. | 2018-10-15 02:33:10 HD Request # 6 | Requesting historical Daily data for RBX18 starting at 2018-10-11 | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2018-10-15 02:33:10 CLX8-NYMEX [CBV] #3 | Reloading chart. | 2018-10-15 02:33:10 HD Request # 5 | Requesting Intraday data. Start date-time: 2018-10-14 19:08:19. Record interval: 0. Symbol: CLX18 | 2018-10-15 02:33:11 CLX8-NYMEX [CBV] [M] Monthly #8 | Reloading chart. | 2018-10-15 02:33:11 HD Request # 5 | Decompressing data. | 2018-10-15 02:33:11 HD Request # 5 | Receiving Intraday data for CLX8-NYMEX starting at 2018-10-14 19:08:19 | 2018-10-15 02:33:11 HD Request # 5 | Timestamp of first Intraday data file record written: 2018-10-14 19:08:25 | 2018-10-15 02:33:11 Socket (1) | Signaling to core to close socket | 2018-10-15 02:33:11 Socket (1) | Shutdown started. Waiting for graceful close. | 2018-10-15 02:33:11 Socket (1) | Socket gracefully closed by remote side. | 2018-10-15 02:33:11 Socket (1) | Closed. | 2018-10-15 02:33:11 CLX8-NYMEX [CBV] 1000 Volume #1 | Study: Display Forex factory calendar news items | Making HTTP request. | 2018-10-15 02:33:15 Chart: CLX8-NYMEX [CBV] 1000 Volume #1 | Study: Display Forex factory calendar news items | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2018-10-15 02:33:15 * HD Request # 5 | Historical data for CLX8-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-10-15 02:33:15 Historical data download thread signaled to stop. | 2018-10-15 02:33:15 HD Request # 5 | Received 27420 records from 2018-10-14 19:08:19 to 2018-10-15 02:23:10 (7.2 hours) and wrote 27410 records for CLX8-NYMEX | 2018-10-15 02:33:15 HD Request # 5 | Completion time: 4s | 2018-10-15 02:33:15 HD Request # 5 | Intraday data download complete for CLX8-NYMEX. Unique request ID: 5 | 2018-10-15 02:33:15 Removed historical data download ID 5 | 2018-10-15 02:33:15 HD Request # 6 | Receiving historical Daily data for RBX8-NYMEX starting at 2018-10-12 | 2018-10-15 02:33:15 HD Request # 6 | Writing historical Daily data to the file RBX8-NYMEX.dly | 2018-10-15 02:33:15 HTTP data.simplesystemtrading.com:80 (1) | Creating socket. | 2018-10-15 02:33:15 HTTP data.simplesystemtrading.com:80 (1) | Connecting to IP: 104.196.53.58. | 2018-10-15 02:33:15 HD Request # 6 | Received 3 records from 2018-10-12 00:00:00 to 2018-10-15 00:00:00 (4.0 days) and wrote 2 records for RBX8-NYMEX | 2018-10-15 02:33:15 HD Request # 6 | Completion time: 4s | 2018-10-15 02:33:15 HD Request # 6 | Daily data download complete for RBX8-NYMEX. Unique request ID: 4 | 2018-10-15 02:33:15 Removed historical data download ID 4 | 2018-10-15 02:33:15 CLX8-NYMEX [CB] 5 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2018-10-15 02:33:15 CLX8-NYMEX [CB] 5 Min #4 | Reloading chart. | 2018-10-15 02:33:15 RBX8-NYMEX [CBV] [M] Daily #13 | Reloading chart. | 2018-10-15 02:33:15 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude Oil.Cht | 2018-10-15 02:33:15 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude Oil.Cht | 2018-10-15 02:33:15 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude Oil.Cht | 2018-10-15 02:33:15 CLX8-NYMEX [CBV] 1000 Volume #1 | Reloading chart. | 2018-10-15 02:33:15 CLX8-NYMEX [CBV] [M] Weekly #7 | Reloading chart. | 2018-10-15 02:33:16 CLX8-NYMEX [CBV] [M] Daily #11 | Reloading chart. | 2018-10-15 02:33:17 CLX8-NYMEX [CBV] 7500 Volume #9 | Reloading chart. | 2018-10-15 02:33:19 Rithmic Trading | Port for executable: 60043 | 2018-10-15 02:33:19 Listening socket (1076). Port 60043 | Closed. | 2018-10-15 02:33:19 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-10-15 02:33:19 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:60043. Current folder: C:\SierraChart\Rim | 2018-10-15 02:33:19 CLX8-NYMEX [CBV] #6 | Reloading chart. | 2018-10-15 02:33:19 CLX8-NYMEX [CBV] #2 | Reloading chart. | 2018-10-15 02:33:19 CLX8-NYMEX [CBV] #3 | Reloading chart. | 2018-10-15 02:33:19 CLX8-NYMEX [CB] 5 Min #4 | Reloading chart. | 2018-10-15 02:33:19 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude Oil.Cht | 2018-10-15 02:33:20 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Crude Oil.Cht | 2018-10-15 02:33:20 CLX8-NYMEX [CBV] [M] 1000 Volume #1 | Performing a full recalculation because it has been tagged. Chartbook: Crude Oil.Cht | 2018-10-15 02:33:20 Rithmic Trading | Bridge process is running. | 2018-10-15 02:33:21 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60043 | 2018-10-15 02:33:21 DTC Client socket (2) | Creating socket. | 2018-10-15 02:33:21 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2018-10-15 02:33:21 Rithmic Trading | Connected to server. | 2018-10-15 02:33:21 Rithmic Trading | Starting socket receive thread. | 2018-10-15 02:33:21 Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-10-15 02:33:21 Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-10-15 02:33:21 Rithmic Trading | Sending logon request message. | 2018-10-15 02:33:21 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-10-15 02:33:21 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-10-15 02:33:21 Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2018-10-15 02:33:21 Rithmic Trading | Message from server: Login call failed. Error code: API_BAD_INPUT | 2018-10-15 02:33:22 Rithmic Trading | Received logon response. | 2018-10-15 02:33:22 Rithmic Trading | Server Name: DTC Bridge. | 2018-10-15 02:33:22 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-10-15 02:33:22 Rithmic Trading | Logon error received from server | 2018-10-15 02:33:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-15 02:33:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-15 02:33:22 Rithmic Trading | Message from server: Deleting API object. | 2018-10-15 02:33:22 DTC Client socket (2) | Socket gracefully closed by remote side. | 2018-10-15 02:33:22 DTC Client socket (2) | Received socket Close event. | 2018-10-15 02:33:22 DTC Client socket (2) | Signaling to core to close socket | 2018-10-15 02:33:22 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-15 02:33:22 DTC Client socket (2) | Closed. | 2018-10-15 02:33:22 Rithmic Trading | Disconnected. | 2018-10-15 02:33:22 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-15 02:33:22 Rithmic Trading | Port for executable: 60074 | 2018-10-15 02:33:24 Listening socket (656). Port 60074 | Closed. | 2018-10-15 02:33:24 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-10-15 02:33:24 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:60074. Current folder: C:\SierraChart\Rim | 2018-10-15 02:33:24 Rithmic Trading | Bridge process is not running! | 2018-10-15 02:33:26 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60074 | 2018-10-15 02:33:26 DTC Client socket (2) | Creating socket. | 2018-10-15 02:33:26 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2018-10-15 02:33:26 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2018-10-15 02:33:27 * DTC Client socket (2) | Signaling to core to close socket | 2018-10-15 02:33:27 DTC Client socket (2) | Closed. | 2018-10-15 02:33:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-15 02:33:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-15 02:33:27 Rithmic Trading | Disconnected. | 2018-10-15 02:33:27 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-15 02:33:27 Rithmic Trading | Port for executable: 60092 | 2018-10-15 02:33:29 Listening socket (1396). Port 60092 | Closed. | 2018-10-15 02:33:29 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-10-15 02:33:29 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:60092. Current folder: C:\SierraChart\Rim | 2018-10-15 02:33:29 |
[2018-10-15 07:16:22] |
Okay understood. This is what we saw as well but we thought it was just related to an invalid username or password because we were trying to connect to the live server without a live account. We do not really know what we can do because we need to debug this but we cannot. The debug version is simply unstable which also indicates that the release build is going to be unstable which may actually be the cause of the problem. At this point we are at a dead-end in regards to this. We are just going to remove this and put the responsibility on Rithmic. They can so easily solve this. That is point-blank obvious. Anyone can see that just by looking at that configuration file we put an image of above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-15 07:17:52
[2018-10-15 07:20:49] |
The prior bridge program is being restored at this time. Should be available in about five minutes. You can update again with Help >> Download Prerelease.
[2018-10-15 11:11:16] |
just an fyi, it connects with the old version and i am receiving streaming data.
[2018-10-15 18:53:02] |
Now even though we could attempt to debug the release build, the problem is that because of the stability issue we see with execution we have no confidence with the debugging process and it gets to be pointless to attempt this until such time that the process is stable. But that is not achievable.
