Date/Time: Sat, 27 Apr 2024 19:49:23 +0000
Chart values/Crosshair tool not working
View Count: 963
[2018-09-26 12:43:19] |
jsob - Posts: 33 |
installed Version 1809 64-bit an hour ago. The Chart Values/Crosshair tool is no longer accessable by either selecting from the Tools menu or clicking on Alt+3: a check mark appears next to the option, but the tool does not display on the chart. Right mouse click is not functional either: I cannot use it to access Studies. F6 will allow me to access Studies
[2018-09-26 12:49:47] |
jsob - Posts: 33 |
update: apologies for not being clear: the tool appears on my charts (the customary cross), but the extended lines with attendant values do not
[2018-09-26 16:26:01] |
The first thing to check is that the settings for the extended lines and values are selected on. You will find them under Global Settings >> Tool Settings >> Chart Values tab. Refer to the following documentation: Chart Drawing Tools: Chart Values Tool Configuration
[2018-09-26 17:03:39] |
jsob - Posts: 33 |
"Show Crosshair.." for both horizontal and vertical lines were selected ON, but without any apparent effect. Clicking ON "Always On When Chart Values Tool Selected" restored the expected display. Seems the default for this item has changed. Thank you for pointing out the functionality.
