Date/Time: Mon, 29 Apr 2024 20:03:33 +0000
[User Discussion] - Highest volume of the day
View Count: 1387
[2018-08-27 18:01:07] |
RonW - Posts: 103 |
I am looking for a way to find the "largest" things in a day: volume, delta, range of a bar, etc. and can't find an easy way. For example, if "Highest High/Lowest Low" study allowed a Length input to be "Since the Start of the Session" rather than just a number? Is there a way to do something like this? Thanks! |
[2018-08-27 18:08:50] |
Have a look at this study: Study Subgraph Daily High Low Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-15 14:05:01] |
RonW - Posts: 103 |
Thank you that was just what I needed. Can I suggest an enhancement? Can you add a 3rd sub graph which displays the Average of the input data for the day? |
[2018-10-15 18:35:09] |
You can do this already. Refer to: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-16 15:16:28] |
RonW - Posts: 103 |
I don't see it... can you be more specific? It looks like the available arithmetic studies would allow me to calculate the average of the high and low, which is the midpoint. But what I want to calculate is the average of the data, which is not the same thing. The existing average studies force you to pick a fixed averaging period. I would like to average always starting at the beginning of the session (kind of like VWAP, but without the weighting). I don't see any studies that would allow that. Am I missing something? Thanks.
[2018-10-16 20:19:13] |
This is the particular study we thought you would use: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=164#Study_Subgraphs_Average This is all the help we can provide. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-16 20:19:30
[2018-10-16 21:51:40] |
Sawtooth - Posts: 3984 |
Have a look at this thread: Reset a Moving Average at the beginnig of each day session ? |
[2018-10-17 02:16:27] |
RonW - Posts: 103 |
Thanks tomgilb that's exactly what I was looking for!
