Date/Time: Sun, 19 May 2024 18:59:30 +0000
Delta Chart
View Count: 1326
[2018-07-25 21:08:03] |
Ryan Bailey - Posts: 51 |
Hello, I have started using your platform so i can replace Blue Water Trading platform and CTS. However I am having trouble matching the accuracy of their delta chart and Market profile. I absolutely love the system but not having a support number i can call or someone to talk to is causing some problems on my end including the ability to build what i need to make this functional. I have been through the support board and no one has answers posted to the questions i have. I need help, and i hope i will get it from this support email because other wise i will be forced to continue with another platform. Ive spent over 20+ hours watching you-tube videos and going through the support board but i can not seem to get the results i need. I am having problems with the Delta chart matching what Blue-Water shows me for Positive or Negative delta on a tick chart. On a 1 min chart its pretty close, but the tick chart is what i need and the results are very much different. Also the market profile chart is using different letters during the day than any other MP chart ive looked at. I really want to use your system but as a full time trader and father i simply cant afford to put any more time in to this. CAN YOU PLEASE HELP? Id be more than happy to pay for remote support and a phone call to get some assistance. Please advise with a response Thanks, |
[2018-07-26 18:04:53] |
We can help you to some extent. As a matter of policy we would not provide support for trying to match a chart in Sierra Chart to another program. We can explain how Delta Volume bars work and that is explained here: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Delta Volume Per Bar Also make sure Sierra Chart is set to a tick by tick data configuration. Follow the instructions here: Tick by Tick Data Configuration Also the market profile chart is using different letters during the day than any other MP chart ive looked at. This is fully documented here:Time Price Opportunity (TPO) Profile Charts: TPO Letter Codes and Letter Customization Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-26 18:18:51
