Date/Time: Fri, 03 May 2024 03:54:55 +0000
Problem with Control Bar
View Count: 977
[2018-07-18 03:51:20] |
EllenT - Posts: 21 |
1. I tried to configure a Control Bar. I created the 2 Fibonacci Retracements, one as TC1 another Fib Retracement with different levels as TC2. I added them to the Control Bar 1, I see the icons on the control bar, both TC1 and TC2 but they refuse to get active. 2. I added some studies to a chart and saved it as a Study, but when I tried to apply it to a new chart, it won't appear. The Unhide studies command did work a couple of times but has stopped now. Any suggestions? Thanks for your help. ElaineS |
[2018-07-18 17:13:09] |
1. Refer to: Chart Drawing Tools: Using Multiple Drawing Tool Configurations You first need to select the Price Retracement tool. 2. It sounds like you may be referring to a Study Collection. For how to use Study Collections, refer to: Study Collections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
