Date/Time: Mon, 29 Apr 2024 20:11:16 +0000
Failed to create/reactive Account on the Barchart system
View Count: 516
[2018-06-30 10:14:01] |
User573855 - Posts: 10 |
Hello, I wanted to connect datafeed but it failed with this message: Action Result: Failed to extend feature expiration date. Failed to create/reactive Account 4941_1 on the Barchart system. Failed to activate the Market Data Feed. To now I traded sim and now I wanted to start to trade real account. It is small $5K account but owner of the account is LTD. company not person. Maybe that means that the account is proffesional? What I have to make for restoring of the datafeed? |
[2018-06-30 22:03:27] |
We will look into this and get back to you.
[2018-07-01 22:59:31] |
I tried to activate the datafeed more times and the last test looks like succesfull and the costs of datafeed have been deducted.
[2018-07-02 06:14:47] |
Hello, something is still wrong. From the opening of market I see figures and volume profile in DoM, but main chart and indicators like relative volume etc. are blank. Costs of datafeed was deducted from my account. |
[2018-07-02 06:40:27] |
but main chart and indicators like relative volume etc. are blank This has no connection to the real-time data feed.If a chart is blank, then refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart In regards to a study, refer to: Chart Studies: Resolving Study Not Visible Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-02 08:32:43] |
Okif I go back in Global Settings - Data Trade Service Setting to SC DATA, the main chart is back but in the same moment stop DoM his work. If I canceled the IB symbol in Chart Setting - Trade and Current Quote Symbol, the Trade Windows the window changes color to SIM trading and all chart works with DoM window. But how to send the orders from Sierra to API TWS in that case?
[2018-07-02 11:25:29] |
You need to follow through the steps here: Sierra Chart Exchange Data Feed: Integration with Trading Services (Integration with Trading Services) You do not need to set Trade and Current Quote Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-02 11:26:07
