Date/Time: Mon, 29 Apr 2024 03:14:34 +0000
Volume by price
View Count: 928
[2018-06-29 14:42:50] |
User173616 - Posts: 2 |
Hello, I would like add volume-by-price studie to my SierraChart, but I failed every time. I want to display it like in you help. ( Volume By Price Study ) Every time I get chart like is on the picture in the annex. I´m using trial, version 1768. Thank you |
sierrachart.jpg / V - Attached On 2018-06-29 14:38:05 UTC - Size: 60.95 KB - 249 views |
[2018-06-29 15:14:06] |
Steve - Posts: 16 |
As a user, I can also give you a little help on this, as I was also playing a lot with VbP study settings: I think what you see is an aggregated volume for several ticks level due to some of your settings, so you need to check all tick size and volume multiplier settings to see if all set to 1 or maybe some of them are set to higher. Check first your data connection is set to 1 tick resolution, than your chart settings if its set to 1 volume multiplier, tick size set auto by the feed, under your VbP study sub settings volume per tick to be set to 1. If all set to 1 than I am out of tips :) |
[2018-06-30 07:40:14] |
Make sure these two settings are both set to 1: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) (Chart Setting) https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#Input_TicksperVolumeBar (Study Input) Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-30 07:41:12
