Date/Time: Mon, 06 May 2024 18:55:22 +0000
Hang up upon loading ESM18
View Count: 617
[2018-06-25 23:15:29] |
User909904 - Posts: 14 |
Hi, I am transferring SC to a new Win10 computer and I run into issue where the SC hangs up when I try to open chart. The chart opens fine on my other computer which is win 8.1. Any idea what could be wrong? thank you Josef Date Time Of Last Edit: 2018-06-25 23:16:28
SC ESM18 hang up.JPG / V - Attached On 2018-06-24 23:40:53 UTC - Size: 105.3 KB - 231 views Owl_sc_ES_15MinCase58.cht - Attached On 2018-06-24 23:41:06 UTC - Size: 86.38 KB - 240 views |
[2018-06-26 08:39:10] |
The chart is using custom studies and most likely the problem is with those. Refer to help topic 17: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface Follow the instructions here to use Safe Mode to workaround this: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-03 21:18:28] |
I was able to resolve the issue with startup that were caused by custom dll using the instructions. Thank you Josef |
