Date/Time: Sun, 19 May 2024 15:52:37 +0000
DOM not showing since rollover
View Count: 744
[2018-06-12 02:39:40] |
Camila - Posts: 21 |
Hi, since I made the rollover, the DOM is not showing anthing at all.. thanks Camila http://www.sierrachart.com/image.php?Image=1528771129561.png |
[2018-06-12 03:11:59] |
Make sure the symbol is set correctly in Chart >> Chart Settings >> Symbol. After that select Chart >> Reset Scales on that window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-12 15:23:32] |
Hi, I did what you said, bur nothing happened. It is still blank and flashing,.. :( thanks |
[2018-06-12 18:07:55] |
For the time being open a new Trading DOM window. Refer to: File Menu: Open Trading DOM (File) And provide that existing one to us by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart We will then see what the problem with it is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-12 18:08:15
[2018-06-13 04:10:40] |
Here it goes
DOM Chartbook.Cht - Attached On 2018-06-13 04:09:12 UTC - Size: 20.69 KB - 281 views |
[2018-06-13 07:37:56] |
Follow through the instructions in the Auto Scale the Chart DOM: The Chart DOM Scale: Auto Scale the Chart DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
